dynamicRefinefvMesh
1 Attachment(s)
I am using Adaptive Mesh Refinement on simulations of rain drop.But the problem is it is not working on the sphere.Does anyone know why? Below are my dynamicMeshDict and setFieldsDict. Thanks in advance, Pete FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicRefineFvMesh; dynamicRefineFvMeshCoeffs { refineInterval 1; field alpha1; lowerRefineLevel 0.0000001; upperRefineLevel 0.999; unrefineLevel 10; nBufferLayers 1; maxRefinement 2; maxCells 500000; correctFluxes ( ( phi U ) ); dumpLevel true; } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha1 0 ); regions ( sphereToCell { centre (0.035 0.01 0.09); radius 0.001; fieldValues ( volScalarFieldValue alpha1 1 volVectorFieldValue U (0 0 -8) ); } boxToCell { box (0 0 0.005) (0.07 0.02 0.01); fieldValues ( volScalarFieldValue alpha1 1 ); } ); // ************************************************** *********************** // |
How many cells do you have before refinement. You can find out by execution of the following command: checkMesh If it is higher than the number maxCells you should increase it. Cheers, Elham |
2 Attachment(s)
Thanks for your reply, but the number is good. I used paraview to get a look of the result. i do not know why it shows like below.
