[mesh manipulation] Merge meshes from many regions |
June 6, 2018, 06:04 |
Christian
Rep Power: 8 |
Dear all,
I have different regions (f01 f03 f05 f07 f12 f14 f16 f22 f24 f31 f33 f41 f43 f52 f02 f04 f06 f11 f13 f15 f21 f23 f25 f32 f34 f42 f51 f61 coolant) with meshes and parameters defined separately. In detail, the structure of my folder is the following: 0: it contains all regions folder for time 0 that are f01 f03 f05 f07 f12 f14 f16 f22 f24 f31 f33 f41 f43 f52 f02 f04 f06 f11 f13 f15 f21 f23 f25 f32 f34 f42 f51 f61 coolant constant: it contains all folders f01, f02,...,coolant for each region system: it contains all folders f01, f02,...,coolant for each region I want to merge the meshes and, more in general, the regions in order to obtain a "master region". I try to use "mergeMeshes" but I obtain errors about finding files. The last one is the following: HTML Code:
--> FOAM FATAL ERROR: Cannot find file "points" in directory "f01/polyMesh" in times 0 down to constant Could you provide suggestions, please? I'm not an expert about mesh management and every advice, explanation and help are welcome Thank you for your time. Regards, Christian |
October 30, 2018, 15:02 |
Martin
Hi Christian, could you solve the problem of merging? I'm trying to do the same...
May 26, 2019, 03:23 |
Christian
Rep Power: 8 |
Dear Martin,
I already read your reply, sorry for the late. However, I solved the problem defining my "master region" in Ansys, saved as .msh. After that, I converted the mesh in OpenFOAM using the command -cellZonesOnly. Christian |
mesh 3d, mesh merge, multiregion meshing |
[ICEM] merge meshes between hexa and prism | jjz2013 | ANSYS Meshing & Geometry | 39 | February 12, 2019 10:38 |
Merge Meshes in parallel | DominicTNC | OpenFOAM | 0 | September 4, 2017 22:39 |
[ICEM] Smoothing before merge meshes | FJSJ | ANSYS Meshing & Geometry | 0 | May 20, 2013 11:30 |
[ICEM] Merge meshes with internal wall | BrolY | ANSYS Meshing & Geometry | 20 | February 20, 2013 10:43 |
Hex and Tet meshes - simplefoam comparison | danvica | OpenFOAM Running, Solving & CFD | 10 | January 4, 2013 01:18 |
