[snappyHexMesh] Surface layer issues.
Old   June 8, 2018, 04:53
Default Surface layer issues.
Stevie_1200's Avatar
Steven Taggart
Stevie_1200 is on a distinguished road
Dear all,
I have been having some issues with the first layer of cells in my mesh. The first layer of cells along a flat surface collapse at one point and the second layer move in to become the first layer. I have been trying to resolve this issue but not having much luck, I would like to sort it before moving on to adding an inflation layer as it was found to make the problem worse.
I have included the sHM dictionary and also attached a screen short of the cells in question.
Many thanks.
Steven
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true; // make basic mesh ?
snap true; // decide to snap back to surface ?
addLayers false; // decide to add viscous layers ?
geometry // Load in STL files here
disc_front.stl {type triSurfaceMesh; name disc_front;}
disc_rear.stl {type triSurfaceMesh; name disc_rear;}
outlet.stl {type triSurfaceMesh; name outlet;}
inlet.stl {type triSurfaceMesh; name inlet;}
back.stl {type triSurfaceMesh; name back;}
front.stl {type triSurfaceMesh; name front;}
wall.stl {type triSurfaceMesh; name wall;}
nozzle_exit.stl {type triSurfaceMesh; name nozzle_exit;}
axis.stl {type triSurfaceMesh; name axis;}
refinementBox
type searchableBox;
min (0.00 -0.002 -0.01);
max (0.015 0.002 0.001);
castellatedMeshControls
maxLocalCells 5000000; //max cells per CPU core
maxGlobalCells 5000000; //max cells to use before mesh deletion step
minRefinementCells 0; //was 0 - zero means no bad cells are allowed during refinement stages
maxLoadUnbalance 0.10;
nCellsBetweenLevels 5; // expansion factor between each high & low refinement zone
// Explicit feature edge refinement
features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command
{file "disc_front.eMesh"; level 0;}
{file "disc_rear.eMesh"; level 0;}
{file "inlet.eMesh"; level 0;}
{file "outlet.eMesh"; level 0;}
{file "back.eMesh"; level 0;}
{file "front.eMesh"; level 0;}
{file "wall.eMesh"; level 0;}
{file "nozzle_exit.eMesh"; level 0;}
{file "axis.eMesh"; level 0;}
// Surface based refinement
refinementSurfaces // Surface-wise min and max refinement level
disc_front {level (3 3);}
disc_rear {level (3 3);}
inlet {level (1 2);}
outlet {level (1 2);}
back {level (1 2);}
front {level (1 2);}
wall {level (3 3);}
nozzle_exit {level (3 3);}
axis {level (0 0);}
resolveFeatureAngle 30; // Resolve sharp angles // Default 30
refinementRegions
refinementBox
mode inside;
levels ((1E15 3));
locationInMesh (0.002 0 -0.004); //to decide which side of mesh to keep **
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
nSmoothPatch 3;
tolerance 2.0;
nSolveIter 130;
nRelaxIter 5;
nFeatureSnapIter 10; // default is 10
// New settings from openfoam 2.2 onwards for SHMesh
implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract
explicitFeatureSnap true; // default is true
multiRegionFeatureSnap false; // deafault is false - detects features between multiple surfaces
// Settings for the layer addition.
addLayersControls //add the PATCH names from inside the STL file so STLpatchName_insideSTLName
relativeSizes false; // was true
layers
disc_front
nSurfaceLayers 1;
disc_rear
nSurfaceLayers 1;
nozzle_exit
nSurfaceLayers 1;
wall
nSurfaceLayers 1;
expansionRatio 1.2;
finalLayerThickness 0.0001; //was 0.00016
minThickness 0.00005; //was 0.00008
nGrow 1; // was 1
// Advanced settings
featureAngle 150; // was 70 //- When not to extrude surface. 0 is flat, 90 is right angle.
nRelaxIter 20; //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh.
nSmoothSurfaceNormals 3; // Number of smoothing iterations of surface normals
nSmoothNormals 4; // Number of smoothing iterations of interior mesh movement direction
nSmoothThickness 10; // Smooth layer thickness over surface patches
maxFaceThicknessRatio 0.5; // Stop layer growth on highly warped cells
maxThicknessToMedialRatio 0.3; // Reduce layer growth where ratio thickness to medial distance is large
minMedianAxisAngle 130; // Angle used to pick up medial axis points
nBufferCellsNoExtrude 0; // Create buffer region for new layer terminations
nLayerIter 50; // Overall max number of layer addition iterations
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
maxNonOrtho 60;
maxBoundarySkewness 2;
maxInternalSkewness 4;
maxConcave 150;
minFlatness 0.5;
minVol 1e-13;
minTetQuality 1e-9;
minArea -1;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.02;
minVolRatio 0.01;
minTriangleTwist -1;
// Advanced
nSmoothScale 4;
errorReduction 0.75;
// Advanced
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
Stevie_1200 is offline   Reply With Quote
boundary cells, snappy hex mesh
[snappyHexMesh] Battling with SnappyHexMexh Nickul OpenFOAM Meshing & Mesh Conversion 2 July 20, 2017 10:32
[snappyHexMesh] Collapsing Layers Tim_Simon OpenFOAM Meshing & Mesh Conversion 5 August 2, 2015 22:51
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 11:27
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 01:44
