[snappyHexMesh] Overlapping cellZones in snappyHexMesh
Old   July 29, 2018, 01:11
Default Overlapping cellZones in snappyHexMesh
Morteza
mortezahdr is on a distinguished road
I have a question about mesh generation with snappyHexMesh when there are multiple regions with mutual volume. I have generated concentric cylinders as separate STL files to give different levels in each region. I have assigned each of them a cellZone, shown in the figure (otherwise they will be removed). But after mesh generation with SHM, only the cylindrical cellZone which includes all cell zones (the biggest one) exist in the cellZones file in polyMesh folder as well as paraview, and other cellZones/patches are not available. As an example, the green patch shown in the image is not available. Is there any way to maintain all cell zones?
Thanks.
mortezahdr is offline   Reply With Quote
cell zones, snappyhexmesh
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] SHM doesn't create cellZones for one region Eko OpenFOAM Meshing & Mesh Conversion 10 January 24, 2018 02:03
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
SnappyHexMesh not creating cellzones Carno OpenFOAM Pre-Processing 0 September 2, 2016 05:24
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
