August 10, 2018, 17:59 |
foam tropology blocks warning;
Rep Power: 7 |
i am trying to generate a simple 2D rectangular mesh as a beginner but i get this error
Creating block mesh from "/home/salma/foam/incompressible/icoFoam/cavity/case0/constant/polyMesh/blockMeshDict" Creating curved edges Creating topology blocks --> FOAM Warning : From function bool Foam::blockMesh::blockLabelsOK(Foam::label, const pointField&, const Foam::cellShape&) const in file blockMesh/blockMeshCheck.C at line 173 out-of-range point label 4 (max = 3) in block 0 Creating topology patches --> FOAM FATAL ERROR: Cannot create mesh due to errors in topology, exiting ! From function Foam:olyMesh* Foam::blockMesh::createTopology(const Foam::IOdictionary&, const Foam::word&) in file blockMesh/blockMeshTopology.C at line 561. FOAM exiting my blockmesh is this way convertToMeters 0.1; vertices ( (0 0 0) //vortice0 (1.5 0 0) //vortice1 (1.5 0.60 0) //vortice2 (0 0.60 0) //vortice3 ); blocks ( hex (0 1 2 3 4) (20 20 0) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type patch; faces ( (0 3 0 0) ); } outlet { type patch; faces ( (1 2 0 0) ); } symmetry { type symmetryPlane; faces ( (3 2 0 0) ); } ); mergePatchPairs ( ); i dont know where is the problem |
August 15, 2018, 22:39 |
Rep Power: 14 |
The error is indicating that the mesher is trying to access a point (4) that doesn't exist. If you are trying to create a 2d rectangular mesh you'll need 8 points -- 2d meshes are created by defining one direction (eg z, for cartesian) as "empty". For a reference case check out the icoFoam tutorials -- it looks like you've been looking at these from the path to the case. Here's an example of the blockMesh for the square cavity, found here : https://github.com/OpenFOAM/OpenFOAM.../cavity/cavity.
Here's the mesh : Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (0 0 0) (1 0 0) (1 1 0) (0 1 0) (0 0 0.1) (1 0 0.1) (1 1 0.1) (0 1 0.1) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1) ); edges ( ); boundary ( movingWall { type wall; faces ( (3 7 6 2) ); } fixedWalls { type wall; faces ( (0 4 7 3) (2 6 5 1) (1 5 4 0) ); } frontAndBack { type empty; faces ( (0 3 2 1) (4 5 6 7) ); } ); mergePatchPairs ( ); // ************************************************************************* // |
#blockmesh |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
[snappyHexMesh] Problem with parallel run of snappyHexMesh | Lorenzo92 | OpenFOAM Meshing & Mesh Conversion | 5 | April 15, 2016 04:12 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
