September 4, 2018, 05:50 |
Multilevels Refinement with cfMesh
Rémy CAVECCHIA
Rep Power: 7 |
I'm currently trying to switch from sHM to cfMesh for my case study and I was wondering if there is a way to set multilevels refinement as you can do it in sHM. For my case study, I'm trying to mesh around a "foil" which is randomly generated and for this purpose I can't be satisfied with using only objectsRefinement and I want to use localRefinement close to my item surface. I achieve this with no problems but I'm used to set multilevels refinement according to different surface distance in sHM and I can't find a way to do the same thing here. Here is my first attempt with only one level: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | cfMesh: A library for mesh generation | | \\ / O peration | | | \\ / A nd | Author: Franjo Juretic | | \\/ M anipulation | E-mail: franjo.juretic@c-fields.com | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object meshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // surfaceFile "airfoil.fms"; minCellSize 0.125; maxCellSize 0.125; boundaryCellSize 0.125; localRefinement { "airfoil" { cellSize 7.8125e-3; refinementThickness 0.05; } } objectRefinements { box1 { type box; cellSize 0.03125; centre (1 0 0.005); lengthX 3; lengthY 1.2; lengthZ 0.01; } box2 { type box; cellSize 0.0625; centre (2.7 0 0.005); lengthX 6.6; lengthY 1.4; lengthZ 0.01; } box3 { type box; cellSize 0.125; centre (11 0 0.005); lengthX 10; lengthY 1.4; lengthZ 0.01; } } boundaryLayers { // nLayers 3; // thicknessRatio 1.2; // maxFirstLayerThickness 0.5; patchBoundaryLayers { "airfoil" { nLayers 10; thicknessRatio 1.2; maxFirstLayerThickness 0.2; allowDiscontinuity 0; } } } renameBoundary { newPatchNames { "airfoil" { type wall; newName airfoil; } } } // ************************************************************************* // And then I tried, as I didn't find any other way to add another localRefinement on the same patch: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | cfMesh: A library for mesh generation | | \\ / O peration | | | \\ / A nd | Author: Franjo Juretic | | \\/ M anipulation | E-mail: franjo.juretic@c-fields.com | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object meshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // surfaceFile "airfoil.fms"; minCellSize 0.125; maxCellSize 0.125; boundaryCellSize 0.125; localRefinement { "airfoil" { cellSize 7.8125e-3; refinementThickness 0.05; } "airfoil" { cellSize 1.5625e-2; refinementThickness 0.2; } } objectRefinements { box1 { type box; cellSize 0.03125; centre (1 0 0.005); lengthX 3; lengthY 1.2; lengthZ 0.01; } box2 { type box; cellSize 0.0625; centre (2.7 0 0.005); lengthX 6.6; lengthY 1.4; lengthZ 0.01; } box3 { type box; cellSize 0.125; centre (11 0 0.005); lengthX 10; lengthY 1.4; lengthZ 0.01; } } boundaryLayers { // nLayers 3; // thicknessRatio 1.2; // maxFirstLayerThickness 0.5; patchBoundaryLayers { "airfoil" { nLayers 10; thicknessRatio 1.2; maxFirstLayerThickness 0.2; allowDiscontinuity 0; } } } renameBoundary { newPatchNames { "airfoil" { type wall; newName airfoil; } } } // ************************************************************************* // Does anyone has any idea how can this be solved?? Thanks. Remy. |
September 18, 2018, 16:58 |
FredPieri
Rep Power: 8 |
Hi ,
I 'am also interested to get the answer to how define multi-refinementThickness on the same object. What i'am currently doing is to declare several primitive ( box, sphere) and use one "refinementThickness" on each. But please note that according to this post: https://www.cfd-online.com/Forums/op...ease-read.html ,I think it is better to post your question there (use the prefix CfMesh): https://www.cfd-online.com/Forums/op...contributions/ cheers fred |
September 18, 2018, 17:08 |
Rémy CAVECCHIA
Rep Power: 7 |
Hi Fred,
That's what I did also but not very efficient as the shape is generated randomly in my case. Thanks for the advice, I didn't notice that there was a dedicated place for cfmesh. I'll correct that quickly. Cheers. Remy |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 13:30 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
