-   OpenFOAM Meshing & Mesh Conversion (https://www.cfd-online.com/Forums/openfoam-meshing/)
-   -   [snappyHexMesh] Curved lines appearing on mesh with snappyHexMesh (https://www.cfd-online.com/Forums/openfoam-meshing/210595-curved-lines-appearing-mesh-snappyhexmesh.html)
gabrielmsa October 30, 2018 12:11
1 Attachment(s)
Greetings!
I have been trying to get rid of the curved lines shown on the picture. The version of OpenFOAM used is 3.0.x. I used a .stl file, then ran snappyHexMesh with only the castellatedMesh control set to true. The mesh was good, so I went to the next step, which was setting the snap control switch set to true. However, after the snappyHexMesh finished the run, I noticed some curved lines on the mesh. I searched information about this but I just couldn't find any. Perhaps I'm using the wrong words, since I'm new to CFD and english is not my native language. Any help is appreciated! Thanks in advance!
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 3;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 1.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 300;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 5;
    // Feature snapping
        //- Number of feature edge snapping iterations.
        //  Leave out altogether to disable.
        nFeatureSnapIter 10;
        //- Detect (geometric) features by sampling the surface
        implicitFeatureSnap true;
        //- Use castellatedMeshControls::features
        explicitFeatureSnap true;
        //- Detect features between multiple surfaces
        //  (only for explicitFeatureSnap, default = false)
        multiRegionFeatureSnap true;
Kind regards
akidess October 31, 2018 03:17
No clue what you are referring to.
