Blockmesh to generate a surface-mounted cube
Dear. Foamers
I tried to generate the mesh on v4.0 using blockMeshDict in a surface-mounted cube tutorial provided by v18.06. However, there were several problems for it. Eventually, I will do LES for a surface-mounted cube. I will appreciate it if you have the mesh for that and can share it. Thanks |
