[snappyHexMesh] After castellated, Snap doesn't "preserve" the aspect ratios of the cubic cells
Old   April 23, 2020, 09:07
Default After castellated, Snap doesn't "preserve" the aspect ratios of the cubic cells
Andrea Stedile
steddy is on a distinguished road
Hi all,
I am trying to make an accurate mesh of an Ahmed body.
This is what the Castellated mesh looks like: https://imgur.com/a/pyZWWaj
All the cells have a nice cubic shape.
This is what the mesh looks like after Snap: https://imgur.com/a/WEn1XwI
You can see that the cells in direct contact with the body's surface have now a "rectangular" shape; wereas in the castellated mesh they were cubes.
In my opinion, this could be an issue in the subsequent phase of layer addition, because the transition from the region to the final layer is disturbed by this weird region, whose cells have a rectangular shape instead of a cubic one.
Are my concerns valid? Could this "error" impair the final result? Can this error be avoided and solved by tuning the mesh quality controls? I am using the default ones: https://pastebin.com/4C0a4yZB
Thank you in advance.
A
This is the relevant content of the snappyHexMeshDict.
geometry
    ahmed
        type triSurfaceMesh;
        // file "ahmed.obj";
        file "ahmed.stl";
    refinementBoxEight
        type searchableBox;
	min (-0.2 -0.25 0.0);
        max (1.1 0.25 0.4);
    refinementBoxSix
        type searchableBox;
        min (-2.0 -0.35 0.0);
        max ( 4.0  0.35 0.5);
    refinementBoxFour
        type searchableBox;
        min (-5.0 -1 0.0);
        max ( 15.0 1.00 0.5);
castellatedMeshControls
    maxLocalCells 10000000;
    maxGlobalCells 200000000;
    minRefinementCells 10;
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 4;
    features
            file "ahmed.eMesh";
            level 8;
    refinementSurfaces
        ahmed
            level (8 8);
            patchInfo
                type wall;
                inGroups (ahmedGroup);
    resolveFeatureAngle 15;
    refinementRegions
        refinementBoxSix
            mode inside;
	    levels ((1E15 6));
        refinementBoxFour
            mode inside;
	    levels ((1E15 4));
        refinementBoxEight
            mode inside;
	    levels ((1E15 8));
    locationInMesh (3.0001 3.0001 0.43);
    allowFreeStandingZoneFaces true;
steddy is offline   Reply With Quote
Old   April 23, 2020, 09:11
Andrea Stedile
I forgot to add that this effect is more or less evident depending by the mesh. In some of my other meshes, it is much more visible: The cells in contact with the body's surface are very long and thin rectangles.
snap
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[OpenFOAM] High Aspect Ratio Cells in Paraview jms ParaView 12 September 13, 2014 16:47
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Automobile aero ground boundary layer OR simpleFoam/GAMG and high aspect ratio cells kyle OpenFOAM Running, Solving & CFD 4 January 4, 2011 11:17
aspect ratio of 3D hex cells Usman FLUENT 1 February 21, 2008 17:54
