blockMesh multiple merging on same hex
1 Attachment(s)
I'm working on mesh which should be merged from four different sub-parts and I'm using blockMesh to do it. I'm on step where I have four blocks (see numbers on the enclosed image). But when I try to merge four boundaries (four dotted lines) only first two merges work fine and on the third merge there is always error like this: Code:
Creating merge patch pairs This happens always on the third merge even if I change the order. So I guess first two are changing something on the geometry and makes next two meshes impossible. I'm using mergePatchPairs because I want to have different mesh sizes on merge faces. Does anyone have any idea what should I do to succeed in merging these four patches? Thanks, Krzysztof |
There is a long-winded way to solve your problem. 1. Create the 4 meshes separately 2. Merge meshes 1 & 2 using mergeMesh. Let us call this mesh12 3. While this is happening, you can concurrently merge meshes 3 & 4 using mergeMesh as well. Let us call this mesh34 4. Use stitchMesh on mesh12 using the right patch of mesh 1 & left patch of mesh 2 are the master & slave patches. 5. After step 4, use createPatch to combine the top surfaces of mesh12 so that you have a single top patch (call top12). Similarly you can do for the bottom surfaces (call it bottom12). 6. Repeat 4 & 5 with mesh34. Call the respective patches top34 & bottom34. 7. Merge meshes mesh12 and mesh34. Call it mesh1234 8. Stitch mesh1234 using top12 and bottom34 as your master & slave patches. End result you will have a single mesh. Alternatively, since mergePatchPairs will work at least once, you could generate two of them together and then do a similar thing as above. So when you create your meshes, instead of creating 4 separate meshes, you could generate say mesh 1 & 2 together (and specify the merging patches in blockMeshDict itself) & do the same for mesh 3 & 4. You then follow step 8 from above with the correct patch names. Hope this helps. Cheers, Antimony |
