Creating a mesh for a flow across an obstacle with Gmsh
Dear community;
I started to work with OpenFOAM 2 months ago, and I feel like I can handle many things by myself right now. However I can't figure out how to create a mesh file using Gmsh. Here is my case: I must simulate a laminar flow of a compressible fluid (gas - Reservoir) in a porous media. But before that, I need to create a development curve, hence, I must create simpler cases and evolve as times goes by. The first case was just as the cavity example in OpenFOAM tutorials directory. Now I must simulate the flow considering 2 obstacles (2 cylinders ). The idea is to simplify the porous media as a flow across several cylinders, in 2D (which means: first 2 cylinders, then 4, then 8 ,then ....). But here is the problem. Ok, I define the geometry easily, Point(1) = {0,0,0}; Point(2) = {1,0,0}; Point(3) = {1,1,0}; Point(4) = {0,1,0}; Point(5) = {0.25, 0.15,0}; Point(6) = {0.25, 0.25,0}; Point(7) = {0.25, 0.35,0}; Point(8) = {0.25, 0.65,0}; Point(9) = {0.25, 0.75,0}; Point(10) = {0.25, 0.85,0}; Line(11) = {1,2}; Line(12) = {2,3}; Line(13) = {3,4}; Line(14) = {4,1}; Circle(15) = {5,6,7}; Circle(16) = {7,6,5}; Circle(17) = {8,9,10}; Circle(18) = {10,9,8}; Line Loop(19) = {11,12,13,14}; Curve Loop(20) = {15,16}; Curve Loop(21) = {17,18}; Plane Surface(22) = {19,20,21}; Transfinite Line{11,12,13,14,15,16,17,18} = 21; Transfinite Surface{21}; Recombine Surface{22}; Until here, everything seems fine, i suppose. But when I try to Extrude the geometry in order to adapt the file for OpenFOAM by using new[] = Extrude{0,0,1/20} { Surface{22}; Layers{1}; Recombine; } The cylinders (the obstacles) don't extrude, and I get the message: "Error: Unknown curve in extruded faces" I wonder if someone could help me with this. I basicly need to know how to generate a 3d file with the "hole" left by the cylinders. Since I must evolve the problem for a more complex geometry, and also the flow will become turbulent, I need to find out how to solve this first task soon. How can I generate the .geo file with the correct geometry and dimensions? I am very sorry if this question turns out to be a stupid one, but since I am new in CFD, I need to learn everything I can in order to improve my skills and become a better professional. |
