[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! |
January 23, 2019, 04:17 |
Rep Power: 12 |
Dear all,
As a OpenFoam newbie, I have been struggling with the concept of creating multiple cell zones in a mesh with snappyHexMesh (later on sHM). I have been searching for guidance in the internet for a while, and it seems that chtMultiRegionFoam from the $FOAM_TUTORIALS should meet my needs. However, after trying over and over again, I have sadly failed to create a mesh with multiple regions. Thus, I would ask for for some guidance from this wonderful forum full of geniouses of OpenFoam. I'm ultimately trying to create a mesh with multiple cell zones with sHM for Fluent. My example case is simply two cylinders wrapped around each other. If you would check the attached picture, you would see an illustration of the case. The inner cylinder has been used to cut the outer volume so that the outer volume has the shape of a pipe or an extruded ring, if you will. Additionally, I have included walls for the outer surfaces of both of the volumes. My snappyHexMeshDict is constructed as follows: Code:
FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers true; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { //walls wall_bigPipe.stl {type triSurfaceMesh; name wall_bigPipe;} wall_smallPipe.stl {type triSurfaceMesh; name wall_smallPipe;} wall_wall1.stl {type triSurfaceMesh; name wall_wall1;} wall_wall2.stl {type triSurfaceMesh; name wall_wall2;} }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 100000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 0; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 1; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { wall_bigPipe { // Surface-wise min and max refinement level level (2 3); faceZone wall_bigPipe; cellZone wall_bigPipe; cellZoneInside inside; } wall_smallPipe { // Surface-wise min and max refinement level level (2 3); faceZone wall_smallPipe; cellZone wall_smallPipe; cellZoneInside inside; } wall_wall1 { level (2 3); } wall_wall2 { level (2 3); } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (0.025 0 0.00); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces false; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 10; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 2.0; //- Number of mesh displacement relaxation iterations. nSolveIter 150; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 10; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. //nFeatureSnapIter 20; //- Detect (geometric) features by sampling the surface (default=false) implicitFeatureSnap false; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; multiRegionFeatureSnap true; } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; // Per final patch (so not geometry!) the layer information layers { } // Expansion factor for layer mesh expansionRatio 1.0; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // is the thickness of the layer furthest away from the wall. // See relativeSizes parameter. finalLayerThickness 0.5; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. minThickness 0.25; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 60; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 10; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 16x! 90 degrees corresponds to 130 in 16x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { #include "meshQualityDict" // Advanced //- Number of error distribution iterations nSmoothScale 5; //- amount to scale back displacement at error points errorReduction 0.75; } // Advanced // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // Code:
splitMeshRegions -cellZonesOnly -overwrite /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-6257b17a4cf8 Exec : splitMeshRegions -cellZonesOnly -overwrite Date : Jan 23 2019 Time : 09:01:59 Host : "myComputer" PID : 17503 I/O : uncollated Case : /home/myName/workFolder/testCase nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Creating single patch per inter-region interface. Using current cellZones to split mesh into regions. This requires all cells to be in one and only one cellZone. Number of regions:2 Writing region per cell file (for manual decomposition) to "/home/myName/workFolder/testCase/constant/cellToRegion" Writing region per cell as volScalarField to "/home/myName/workFolder/testCase/0/cellToRegion" Region Cells ------ ----- 0 0 1 23840 Region Zone Name ------ ---- ---- 0 0 wall_bigPipe 1 1 wall_smallPipe Sizes of interfaces between regions: Interface Region Region Faces --------- ------ ------ ----- Reading volScalarField cellToRegion Adding patches Adding patches Region 0 -------- Creating mesh for region 0 wall_bigPipe Testing:"/home/myName/workFolder/testCase/system/wall_bigPipe/fvSchemes" Writing dummy "wall_bigPipe/fvSchemes" Writing dummy "wall_bigPipe/fvSolution" Mapping fields Mapping field cellToRegion Deleting empty patches Writing new mesh Writing addressing to base mesh Writing map pointRegionAddressing from region0 points back to base mesh. Writing map faceRegionAddressing from region0 faces back to base mesh. Writing map cellRegionAddressing from region0 cells back to base mesh. Writing map boundaryRegionAddressing from region0 boundary back to base mesh. Region 1 -------- Creating mesh for region 1 wall_smallPipe Testing:"/home/myName/workFolder/testCase/system/wall_smallPipe/fvSchemes" Mapping fields Mapping field cellToRegion Deleting empty patches Writing new mesh Writing addressing to base mesh Writing map pointRegionAddressing from region1 points back to base mesh. Writing map faceRegionAddressing from region1 faces back to base mesh. Writing map cellRegionAddressing from region1 cells back to base mesh. Writing map boundaryRegionAddressing from region1 boundary back to base mesh. End I realize that similar question have been asked before but I am still eager to ask this question in a new thread, seeing that I could not find suitable solution for my problem elsewhere. If anyone could shed some light into this mess, I would not hesitate to give my highest regards and all the thumbs up symbols CFD Online will provide! -d edit: The reason for wanting separate cell zones is to define one region as a solid and the second one as fluid. Last edited by divergence; January 23, 2019 at 05:39. |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[Workbench] Creation of Cell Zones for processing in FLUENT | kailingkk | ANSYS Meshing & Geometry | 0 | October 5, 2013 05:09 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
