[snappyHexMesh] Error snappyhexmesh - Multiple outside loops |
March 11, 2014, 03:09 |
avinashjagdale
Rep Power: 12 |
following is the error I am getting in smoothing process of snappyhexmesh.
I have meshed the same geometry with fine grids and it worked. Now with coarse meshing levels I am getting this error .................................................. .................................................. ...... Multiple outside loops:0() From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::combineFaces::getOutsideFace(Foam::Primitive Patch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libautoMesh.so" #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libautoMesh.so" #7 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/snappyHexMesh" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/snappyHexMesh" .................................................. .................................................. .................... What is the reason? |
March 11, 2014, 06:30 |
avinashjagdale
Rep Power: 12 |
DEar Foamers
I solved the problem. yeah! I further increased the scale for edge feature refinement from 3 to 4 . and also increased refinement level for surface corners. It worked superb. Hence the problem but be related to edges of the geometry. Still I would like to know exactly when that problem arises. If anyone could help. I am attaching snapshots of mesh. |
April 25, 2014, 20:56 |
Lucas Mutti
Rep Power: 13 |
I have the same problem happening and I would say this is related to the fact that I just installed ParaView 4.0. I was running the same exact case on 3.14 and I had no problem.
It seems that is like you said, I increased my refinement level from 4 to 5 and the problem was gone. Yet, I don't quite understand the reason behind. Cheers |
April 26, 2014, 07:48 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@avinashjagdale: If you can provide a test case that reproduces this problem, I can have a look into it. Without a test case, I can only guess that it's a bug and possibly one that has already been fixed in OpenFOAM 2.3.x. @Lucas: As I stated in the other thread (http://www.cfd-online.com/Forums/ope...tml#post488338 post #8), without knowing which steps you've taken to change between versions of ParaView, I'm not able to deduce why this happened in your case, because OpenFOAM should not be affected by ParaView. Well, there is a possibility: you might have installed both OpenFOAM 2.2 and 2.3 from Deb packages and now have a mixed shell environment; this can lead to libraries being used between OpenFOAM versions and I find it strange that it hasn't crashed something more along the way... Best regards, Bruno
April 26, 2014, 15:52 |
Lucas Mutti
Rep Power: 13 |
Hey Bruno,
Thanks for the response. I have installed two different versions of OpenFOAM because my ParaView 3.12 has crashed as I explained in the post you have just referenced. It is interesting that by installing ParaView 4.0 it overwrites 3.12. Cheers |
October 28, 2014, 03:34 |
matteo lombardi
Rep Power: 17 |
I am having the same error as reported in this thread: Merging all faces of a cell --------------------------- - which are on the same patch - which make an angle < 180 degrees (cos:-1) - as long as the resulting face doesn't become concave by more than 90 degrees (0=straight, 180=fully concave) [56] [56] [56] --> FOAM FATAL ERROR: [56] Multiple outside loops:0() [56] [56] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [56] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [56] This happens at the beginning of the Layer phase (running SHM 2.3.x updated about 2 weeks ago). I have checked the snapped mesh and it looks fine and passes all checkmesh criteria. Furthermore I have meshed very similar geometries without any issues.. Any hints about what could be the problem?(sorry I can post the geoemtry becuase it is confedential). Thanks Matteo |
November 1, 2014, 15:06 |
#7 | ||
Bruno Santos
Rep Power: 128 |
Greetings Matteo,
checkMesh -allTopology -allGeometry Quote:
But did you try the solution mentioned in the posts above? Namely to increase the refinement level, previous to the layer adding step? In addition, this reminds me of this bug report: http://www.openfoam.org/mantisbt/view.php?id=1376 By the way, proper visual mesh diagnosis is explained here: http://openfoamwiki.net/index.php/FA...is_in_ParaView Best regards, Bruno
August 9, 2015, 06:53 |
SnappyHexmesh using all my RAM and not finalising
nasir musa yakubu
Rep Power: 12 |
i have started building my case and trying to run my mesh. however it doesn’t work completely.
i started of modifying the snappyhexmesh contained in the snappy multi region heater case but it ended up taking allot of time and using up my most of my RAM, and when ever it ended, the meshing doesnt finalise and when i view it on paraview, it all seems like lego assembly and the surfaces not properly refined. Also some portion of the geometry,s seems erased. After multiple trials, i decided to use a copy of the snappyhezmeshdict made by douglas, the mesh of the geometries got better with less portions erased but still looks like lego assembly. i have attached my new snappyhexmesh file (snappyhexmeshdict ) - source http://www.calumdouglas.ch/openfoam-...snappyhexmesh/ and the old modified (snappyhexmeshdict-) - source multi region heater case, to help you to have a clearer picture of what am trying to do. Note: the filenames are modified with ( - ) symbol at the end of the file name. ( - ) meaning modified snappyhexmesh from multi region heater case. thanks Also, when ever i run my mesh using this procedure: Procedure for Meshing in Parallel with snappyHexMesh (SHMesh) (replace the number “8” with how ever many cores you have & make sure your decomposeParDict matches) ---------------------------------------------------------------------- 1 Rename 0 folder 0.org This prevents SHMesh interfering with it 2 <blockMesh> Creates background mesh for SHMesh 3 <surfaceFeatureExtract> So the mesher knows where to snap to 4 <decomposePar> Divides mesh into one section per CPU core 5 <mpirun -np 8 snappyHexMesh -overwrite -parallel> Runs mesher in parallel 6 <reconstructParMesh -constant> Puts the mesh back together again 7 delete all processor folders Clear old mesh data 8 delete folder 0 This was a dummy folder for SHMesh 9 rename folder 0.org to 0 Reactivate the folder for the solver to use ----------------------i get the following results: also this is what i get at the end of my meshing: and for the past 2 days, i have not been able to reolve the problem, i ve tried changing the quality parameters, enable and disable layers but nothing seem to work. i would appreciate ur guidance on this issue. thanks Code:
Morph iteration 19 ----------------- Calculating patchDisplacement as distance to nearest surface point ... Wanted displacement : average:1.230944e-06 min:3.925231e-17 max:0.0002688459 Calculated surface displacement in = 9.63 s Detecting near surfaces ... Overriding nearest with intersection of close gaps at 2820 out of 5939704 points. Overriding displacement on features : implicit features : false explicit features : true multi-patch features : false Detected 46443 baffle edges out of 11710903 edges. Initially selected 106031 points out of 5939704 for reverse attraction. Selected 303606 points out of 5939704 for reverse attraction. Stringing feature edges : changed 18457 points Stringing feature edges : changed 2631 points Stringing feature edges : changed 519 points Stringing feature edges : changed 151 points Stringing feature edges : changed 55 points Stringing feature edges : changed 38 points Stringing feature edges : changed 19 points Stringing feature edges : changed 12 points Stringing feature edges : changed 6 points Stringing feature edges : changed 7 points Stringing feature edges : changed 5 points Stringing feature edges : changed 5 points Stringing feature edges : changed 1 points Stringing feature edges : changed 3 points Stringing feature edges : changed 0 points Attraction: linear : max-0.0002563777 -8.09235e-05 0) avg2.441981e-09 -1.647495e-09 -4.241837e-09) feature : max0.002114379 -2.389529e-05 -1.870423e-05) avg-2.423215e-08 1.672902e-07 1.467123e-08) Feature analysis : total master points:5812386 attraction to : feature point : 23 feature edge : 87832 nearest surface : 0 rest : 5724531 --> FOAM Warning : Displacement (1.965109e-12 6.576623e-09 3.403723e-12) at mesh point 269808 coord (0.02751599 0.08092443 0.01406182) points through the surrounding patch faces Smoothing displacement ... Iteration 0 Iteration 10 Iteration 20 Iteration 30 Iteration 40 Displacement smoothed in = 52.88 s Moving mesh ... Iteration 0 Moving mesh using displacement scaling : min:1 max:1 Checking faces in error : non-orthogonality > 98 degrees : 12122 faces with face pyramid volume < 1e-15 : 46438 faces with face-decomposition tet quality < 1e-11 : 48596 faces with concavity > 90 degrees : 2 faces with skewness > 4 (internal) or 20 (boundary) : 32 faces with interpolation weights (0..1) < 0.01 : 60 faces with volume ratio of neighbour cells < 0.01 : 148 faces with face twist < 0.02 : 2703 faces on cells with determinant < 0.001 : 259 Iteration 1 Moving mesh using displacement scaling : min:0.85 max:1 Checking faces in error : non-orthogonality > 98 degrees : 10623 faces with face pyramid volume < 1e-15 : 43100 faces with face-decomposition tet quality < 1e-11 : 44795 faces with concavity > 90 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 26 faces with interpolation weights (0..1) < 0.01 : 36 faces with volume ratio of neighbour cells < 0.01 : 129 faces with face twist < 0.02 : 2955 faces on cells with determinant < 0.001 : 225 Iteration 2 Moving mesh using displacement scaling : min:0.7225 max:1 Checking faces in error : non-orthogonality > 98 degrees : 9163 faces with face pyramid volume < 1e-15 : 40280 faces with face-decomposition tet quality < 1e-11 : 41785 faces with concavity > 90 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 16 faces with interpolation weights (0..1) < 0.01 : 51 faces with volume ratio of neighbour cells < 0.01 : 114 faces with face twist < 0.02 : 3035 faces on cells with determinant < 0.001 : 185 Iteration 3 Moving mesh using displacement scaling : min:0.614125 max:1 Checking faces in error : non-orthogonality > 98 degrees : 7854 faces with face pyramid volume < 1e-15 : 37915 faces with face-decomposition tet quality < 1e-11 : 39197 faces with concavity > 90 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 16 faces with interpolation weights (0..1) < 0.01 : 42 faces with volume ratio of neighbour cells < 0.01 : 115 faces with face twist < 0.02 : 3120 faces on cells with determinant < 0.001 : 148 Iteration 4 Moving mesh using displacement scaling : min:0.5220062 max:1 Checking faces in error : non-orthogonality > 98 degrees : 6583 faces with face pyramid volume < 1e-15 : 35743 faces with face-decomposition tet quality < 1e-11 : 36868 faces with concavity > 90 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 10 faces with interpolation weights (0..1) < 0.01 : 35 faces with volume ratio of neighbour cells < 0.01 : 100 faces with face twist < 0.02 : 3358 faces on cells with determinant < 0.001 : 120 Iteration 5 Moving mesh using displacement scaling : min:0.4437053 max:1 Checking faces in error : non-orthogonality > 98 degrees : 5609 faces with face pyramid volume < 1e-15 : 33258 faces with face-decomposition tet quality < 1e-11 : 34961 faces with concavity > 90 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 6 faces with interpolation weights (0..1) < 0.01 : 13 faces with volume ratio of neighbour cells < 0.01 : 59 faces with face twist < 0.02 : 3536 faces on cells with determinant < 0.001 : 103 Iteration 6 Moving mesh using displacement scaling : min:0.3771495 max:1 Checking faces in error : non-orthogonality > 98 degrees : 4754 faces with face pyramid volume < 1e-15 : 30953 faces with face-decomposition tet quality < 1e-11 : 33067 faces with concavity > 90 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 6 faces with interpolation weights (0..1) < 0.01 : 17 faces with volume ratio of neighbour cells < 0.01 : 63 faces with face twist < 0.02 : 3749 faces on cells with determinant < 0.001 : 89 Iteration 7 Displacement scaling for error reduction set to 0. Moving mesh using displacement scaling : min:0.3205771 max:1 Checking faces in error : non-orthogonality > 98 degrees : 3936 faces with face pyramid volume < 1e-15 : 28696 faces with face-decomposition tet quality < 1e-11 : 31573 faces with concavity > 90 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 12 faces with interpolation weights (0..1) < 0.01 : 11 faces with volume ratio of neighbour cells < 0.01 : 65 faces with face twist < 0.02 : 4068 faces on cells with determinant < 0.001 : 69 Iteration 8 Moving mesh using displacement scaling : min:0 max:1 Checking faces in error : non-orthogonality > 98 degrees : 4 faces with face pyramid volume < 1e-15 : 15 faces with face-decomposition tet quality < 1e-11 : 842 faces with concavity > 90 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.01 : 0 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.02 : 88 faces on cells with determinant < 0.001 : 2 Iteration 9 Moving mesh using displacement scaling : min:0 max:1 Checking faces in error : non-orthogonality > 98 degrees : 0 faces with face pyramid volume < 1e-15 : 0 faces with face-decomposition tet quality < 1e-11 : 19 faces with concavity > 90 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.01 : 0 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.02 : 4 faces on cells with determinant < 0.001 : 0 Iteration 10 Moving mesh using displacement scaling : min:0 max:1 Checking faces in error : non-orthogonality > 98 degrees : 0 faces with face pyramid volume < 1e-15 : 0 faces with face-decomposition tet quality < 1e-11 : 1 faces with concavity > 90 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.01 : 0 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.02 : 1 faces on cells with determinant < 0.001 : 0 Iteration 11 Moving mesh using displacement scaling : min:0 max:1 Checking faces in error : non-orthogonality > 98 degrees : 0 faces with face pyramid volume < 1e-15 : 0 faces with face-decomposition tet quality < 1e-11 : 0 faces with concavity > 90 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.01 : 0 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.02 : 0 faces on cells with determinant < 0.001 : 0 Successfully moved mesh Moved mesh in = 110.48 s Repatching faces according to nearest surface ... Repatched 26188 faces in = 4.05 s Edge intersection testing: Number of edges : 37670275 Number of edges to retest : 18219085 Number of intersected edges : 5705897 [3] [3] [3] --> FOAM FATAL ERROR: [3] Multiple outside loops:0() [3] [3] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [3] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [3] FOAM parallel run aborting [3] [3] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [3] #1 Foam::error::abort() at ??:? [3] #2 Foam::combineFaces::getOutsideFace(Foam::Primitive Patch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [3] #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [3] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? [3] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [3] #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) at ??:? [3] #7 ? at ??:? [3] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [3] #9 ? at ??:? -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [13] [13] [13] --> FOAM FATAL ERROR: [13] Multiple outside loops:0() [13] [13] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [13] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [13] FOAM parallel run aborting [13] [13] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [13] #1 Foam::error::abort() at ??:? [13] #2 Foam::combineFaces::getOutsideFace(Foam::Primitive Patch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [13] #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [13] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? [13] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [13] #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) at ??:? [13] #7 ? at ??:? [13] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [13] #9 ?[14] [14] [14] --> FOAM FATAL ERROR: [14] Multiple outside loops:0() [14] [14] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [14] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [14] FOAM parallel run aborting [14] [14] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [14] #1 Foam::error::abort() at ??:? [14] #2 Foam::combineFaces::getOutsideFace(Foam::Primitive Patch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [14] #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [14] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? [14] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [14] #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) at ??:? [14] #7 -------------------------------------------------------------------------- mpirun has exited due to process rank 3 with PID 4954 on node ubuntu exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- parallels@ubuntu:~/OpenFOAM-2.4.0/receiver$ Last edited by wyldckat; August 9, 2015 at 14:05. Reason: Added [CODE][/CODE] markers and repaired link |
September 27, 2015, 23:13 |
#9 |
Rep Power: 24 |
How much memory does your machine have? Have you tried making the mesh coarser and seeing if that completes?
November 16, 2015, 20:33 |
#10 |
nasir musa yakubu
Rep Power: 12 |
Hello Bruno, I am having the same issue when i select face ype as boundary or baffle in SHMDict file. i can provide my test case if anyone can help highlight the reason the mesh is failing to snap. i have looked at mesh in paraview, and it seems like thin structure with thickness of 0.02mm have poorly refined cellzones, but the face zone seems well refined. i have my edge and surface refinement level set to 7 and (5-5) respective.
i would really appreciate some guidance. thanks |
November 17, 2015, 05:32 |
#11 |
nasir musa yakubu
Rep Power: 12 |
hello i have the same issue and i don't know why it keeps failing to snap. please help, have a look at my log bellow, i am happy to provide a test case if someone wants to have a look
Morph iteration 9 ----------------- Calculating patchDisplacement as distance to nearest surface point ... Wanted displacement : average:1.370954e-05 min:8.056865e-13 max:0.0006725203 Calculated surface displacement in = 3.65 s Detecting near surfaces ... Overriding nearest with intersection of close gaps at 0 out of 4569281 points. Overriding displacement on features : implicit features : true explicit features : true multi-patch features : true Detected 2662845 baffle edges out of 7912799 edges. Initially selected 2743783 points out of 4569281 for reverse attraction. Selected 3875216 points out of 4569281 for reverse attraction. Removing constraints near multi-patch points : changed 10981 points Stringing feature edges : changed 425773 points Stringing feature edges : changed 69259 points Stringing feature edges : changed 10189 points Stringing feature edges : changed 4830 points Stringing feature edges : changed 3430 points Stringing feature edges : changed 2310 points Stringing feature edges : changed 1764 points Stringing feature edges : changed 1340 points Stringing feature edges : changed 1051 points Stringing feature edges : changed 757 points Stringing feature edges : changed 582 points Stringing feature edges : changed 506 points Stringing feature edges : changed 395 points Stringing feature edges : changed 293 points Stringing feature edges : changed 255 points Stringing feature edges : changed 222 points Stringing feature edges : changed 163 points Stringing feature edges : changed 149 points Stringing feature edges : changed 126 points Stringing feature edges : changed 117 points Stringing feature edges : changed 86 points Stringing feature edges : changed 77 points Stringing feature edges : changed 57 points Stringing feature edges : changed 55 points Stringing feature edges : changed 46 points Stringing feature edges : changed 37 points Stringing feature edges : changed 39 points Stringing feature edges : changed 40 points Stringing feature edges : changed 33 points Stringing feature edges : changed 32 points Stringing feature edges : changed 19 points Stringing feature edges : changed 18 points Stringing feature edges : changed 11 points Stringing feature edges : changed 9 points Stringing feature edges : changed 4 points Stringing feature edges : changed 8 points Stringing feature edges : changed 5 points Stringing feature edges : changed 1 points Stringing feature edges : changed 1 points Stringing feature edges : changed 3 points Stringing feature edges : changed 1 points Stringing feature edges : changed 1 points Stringing feature edges : changed 1 points Stringing feature edges : changed 1 points Stringing feature edges : changed 0 points Attraction: linear : max:(-1.387779e-17 0.0006725203 2.775558e-17) avg:(7.074867e-08 1.006497e-06 8.624391e-08) feature : max:(-2.074497e-05 0.0006725203 -1.258836e-05) avg:(-2.008766e-09 9.162091e-08 -2.517807e-09) Feature analysis : total master points:4512468 attraction to : feature point : 0 feature edge : 1873677 nearest surface : 0 rest : 2638791 --> FOAM Warning : Displacement (1.63064e-16 -4.268701e-08 -6.678685e-17) at mesh point 72522 coord (0.02812652 0.007193704 0.007520359) points through the surrounding patch faces Smoothing displacement ... Iteration 0 Iteration 10 Iteration 20 Displacement smoothed in = 45.89 s Moving mesh ... Iteration 0 Moving mesh using displacement scaling : min:1 max:1 Checking faces in error : faces with face pyramid volume < 0 : 737032 faces with face-decomposition tet quality < 0 : 445142 faces with skewness > 1 (internal) or 1 (boundary) : 1369717 faces with interpolation weights (0..1) < 1e-07 : 5 faces with volume ratio of neighbour cells < 1e-08 : 0 faces with face twist < 2e-07 : 57077 faces on cells with determinant < 1e-07 : 53627 . . . . . . Iteration 5 Displacement scaling for error reduction set to 0. Moving mesh using displacement scaling : min:0.2373047 max:1 Checking faces in error : faces with face pyramid volume < 0 : 131401 faces with face-decomposition tet quality < 0 : 176287 faces with skewness > 1 (internal) or 1 (boundary) : 707431 faces with interpolation weights (0..1) < 1e-07 : 0 faces with volume ratio of neighbour cells < 1e-08 : 0 faces with face twist < 2e-07 : 21 faces on cells with determinant < 1e-07 : 150 Iteration 6 Moving mesh using displacement scaling : min:0 max:1 Checking faces in error : faces with face pyramid volume < 0 : 4492 faces with face-decomposition tet quality < 0 : 7438 faces with skewness > 1 (internal) or 1 (boundary) : 46426 faces with interpolation weights (0..1) < 1e-07 : 0 faces with volume ratio of neighbour cells < 1e-08 : 0 faces with face twist < 2e-07 : 1 faces on cells with determinant < 1e-07 : 13 Iteration 7 Moving mesh using displacement scaling : min:0 max:1 Checking faces in error : faces with face pyramid volume < 0 : 38 faces with face-decomposition tet quality < 0 : 485 faces with skewness > 1 (internal) or 1 (boundary) : 26611 faces with interpolation weights (0..1) < 1e-07 : 0 faces with volume ratio of neighbour cells < 1e-08 : 0 faces with face twist < 2e-07 : 0 faces on cells with determinant < 1e-07 : 0 Iteration 8 Moving mesh using displacement scaling : min:0 max:1 Checking faces in error : faces with face pyramid volume < 0 : 40 faces with face-decomposition tet quality < 0 : 235 faces with skewness > 1 (internal) or 1 (boundary) : 25880 faces with interpolation weights (0..1) < 1e-07 : 0 faces with volume ratio of neighbour cells < 1e-08 : 0 faces with face twist < 2e-07 : 0 faces on cells with determinant < 1e-07 : 0 Successfully moved mesh Moved mesh in = 418.66 s Repatching faces according to nearest surface ... Repatched 0 faces in = 2.56 s Edge intersection testing: Number of edges : 44322103 Number of edges to retest : 14809692 Number of intersected edges : 4752278 [13] [13] [13] --> FOAM FATAL ERROR: [13] Multiple outside loops:0() [13] [13] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [13] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [13] FOAM parallel run aborting [13] [13] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [13] #1 Foam::error::abort()[4] [4] [4] --> FOAM FATAL ERROR: [4] Multiple outside loops:0() [4] [4] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [4] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [4] FOAM parallel run aborting [4] [4] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [13] #2 Foam::combineFaces::getOutsideFace(Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [4] #1 Foam::error::abort() at ??:? [13] #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [13] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? [4] #2 Foam::combineFaces::getOutsideFace(Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [13] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [4] #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [13] #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&)[12] [12] [12] --> FOAM FATAL ERROR: [12] Multiple outside loops:0() [12] [12] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [12] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [12] FOAM parallel run aborting [12] [12] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [4] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? [13] #7 at ??:? [12] #1 Foam::error::abort() at ??:? [4] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&)? at ??:? [4] #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) at ??:? [13] #8 __libc_start_main at ??:? [12] #2 Foam::combineFaces::getOutsideFace(Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [4] #7 in "/lib/x86_64-linux-gnu/libc.so.6" [13] #9 at ??:? [12] #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&)?? at ??:? at ??:? [4] #8 __libc_start_main[12] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 13 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- in "/lib/x86_64-linux-gnu/libc.so.6" [4] #9 ? at ??:? [12] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&)[6] [6] [6] --> FOAM FATAL ERROR: [6] Multiple outside loops:0() [6] [6] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [6] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [6] FOAM parallel run aborting [6] [6] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [6] #1 Foam::error::abort() at ??:? [6] #2 Foam::combineFaces::getOutsideFace(Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [6] #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [6] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? [6] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [6] #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) at ??:? [6] #7 ? at ??:? [6] #8 __libc_start_main[7] [7] [7] --> FOAM FATAL ERROR: [7] Multiple outside loops:0() [7] [7] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [7] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [7] FOAM parallel run aborting [7] [7] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [7] #1 Foam::error::abort() at ??:? [7] #2 Foam::combineFaces::getOutsideFace(Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [7] #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [7] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? [7] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [7] #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) at ??:? [7] #7 ? at ??:? [7] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [7] #9 [11] [11] [11] --> FOAM FATAL ERROR: [11] Multiple outside loops:0() [11] [11] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [11] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [11] FOAM parallel run aborting [11] [11] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [11] #1 Foam::error::abort() at ??:? [11] #2 Foam::combineFaces::getOutsideFace(Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [11] #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [11] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? [11] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [11] #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) at ??:? [11] #7 ? at ??:? [11] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [11] #9 ? at ??:? at ??:? [12] #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) at ??:? [12] #7 ? at ??:? [12] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [12] #9 ? at ??:? [14] [14] [14] --> FOAM FATAL ERROR: [14] Multiple outside loops:0() [14] [14] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [14] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [14] FOAM parallel run aborting [14] [14] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [14] #1 Foam::error::abort() at ??:? [14] #2 Foam::combineFaces::getOutsideFace(Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [14] #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [14] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? [14] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [14] #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) at ??:? [14] #7 ? at ??:? [14] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [14] #9 ? at ??:? [15] [15] [15] --> FOAM FATAL ERROR: [15] Multiple outside loops:0() [15] [15] From function combineFaces::getOutsideFace(const indirectPrimitivePatch&) [15] in file polyTopoChange/polyTopoChange/combineFaces.C at line 423. [15] FOAM parallel run aborting [15] [15] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [15] #1 Foam::error::abort() at ??:? [15] #2 Foam::combineFaces::getOutsideFace(Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [15] #3 Foam::combineFaces::validFace(double, Foam::PrimitivePatch<Foam::face, Foam::IndirectList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:? [15] #4 Foam::combineFaces::getMergeSets(double, double, Foam::HashSet<int, Foam::Hash<int> > const&) const at ??:? [15] #5 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [15] #6 Foam::autoSnapDriver::doSnap(Foam::dictionary const&, Foam::dictionary const&, double, double, Foam::snapParameters const&) at ??:? [15] #7 ? at ??:? [15] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [15] #9 ? at ??:? at ??:? -------------------------------------------------------------------------- mpirun has exited due to process rank 13 with PID 3920 on node ubuntu exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [ubuntu:03881] 5 more processes have sent help message help-mpi-api.txt / mpi-abort [ubuntu:03881] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages parallels@ubuntu:~/OpenFOAM-2.4.0/chtMRF$ |
November 22, 2015, 15:51 |
#12 |
Bruno Santos
Rep Power: 128 |
Hi Nasir,
I can try and take a look at your case, although it would help a lot if you have a much smaller test case, i.e. something that doesn't need 5 million cells I say this because by machine at home only has 6 GB of RAM and won't be able to mesh this. Best regards, Bruno
November 22, 2015, 16:30 |
#13 |
Rep Power: 24 |
I could mesh this if wyldckat can use his superior foam-knowledge to help solve the problem!
November 23, 2015, 15:17 |
#14 |
Bruno Santos
Rep Power: 128 |
Hi me3840,
Are you willing to help in literally hunt down the bug? We can try doing an assisted debugging session, where:
I say this because this looks like a pretty crazy bug that I would like to hunt down, because the error message claims: Code:
Multiple outside loops:0() The annoying part is that I've got the very vague feeling I've also tripped over this bug sometime in the past, but I can't remember when or why or how I solved it I can only guess that it was in fact the problem that avinashjagdale mentioned in the first post. Best regards, Bruno |
November 24, 2015, 19:12 |
#15 |
Rep Power: 24 |
Wyldckat,
Sounds like fun, let's give it a go. Are all the files in post 8, and are you just using the source from earlier in the thread? |
November 25, 2015, 14:22 |
#16 |
nasir musa yakubu
Rep Power: 12 |
Hello Bruno,
Thanks for your prompt reply, i have been away and couldn't reply. i could create a simple case but i reckon, it will be more efficient to use team viewer and you can remotely use my pc and have discussions quite easily. let me know if it is ok with you and i we can arrange anytime thats most convenient for you and i will email you my username and password + (Skype) or something else. so far i couldn't resolve the issue but i was able to avoid but not revolve it by removing face type boundary from snappyhexmeshdict. i am carefully using the word avoid because, even though my mesh gets to finalise, for some reason the internal mesh has some parts missing. when i set Code:
allowFreeStandingZoneFaces false; Code:
allowFreeStandingZoneFaces true; i am happy to help in resolving the bug, but i am a newbie and ve no experience writing c++ codes. so i am sorry. kind regards nas |
November 28, 2015, 10:07 |
#17 | |||
Bruno Santos
Rep Power: 128 |
Greetings to all!
I'll try to answer to your both: Quote:
Then ask Nasir via private message for the case. Please let me know when you have everything ready, but in the meantime I'll prepare a branch of OpenFOAM 2.4.x in my repository for debugging the issue. Quote:
Either way, the most efficient way to diagnose the issue is to have a small test case. In addition, I have several OpenFOAM versions installed in my machine, which easily allows me to test with various versions to assess if the bug didn't exist in older or newer versions or even in variants of OpenFOAM, which is why I also prefer a smaller test case. Quote:
And Nasir, if you prefer to build and test this yourself in your machine, instead of asking me3840 to assist in debugging the problem, you can try as well by using the instructions I'll provide in a few minutes. Best regards, Bruno |
November 28, 2015, 12:54 |
#18 |
Bruno Santos
Rep Power: 128 |
Greetings to all once again!
It took me a bit longer than I had planned, as I had to take care of a few other things. The instructions for getting the code I uploaded a few minutes ago is as follows and should only be used with OpenFOAM 2.4.x: Code:
foam git remote add wyldckat https://github.com/wyldckat/OpenFOAM-2.4.x.git git fetch wyldckat git checkout MultiOLoops wmake libso src/dynamicMesh Code:
mpirun -np 8 snappyHexMesh -overwrite -parallel > log.snappyHexMesh 2>&1 Code:
gzip < log.snappyHexMesh > log.snappyHexMesh.gz Best regards, Bruno |
November 28, 2015, 15:22 |
#19 |
nasir musa yakubu
Rep Power: 12 |
I will try to follow, the procedure by Bruno, however, i reckon, the main problem is that SnappyHexMesh is not capable of handling multi volume mesh for surfaces with thickness bellow 0.025mm. as you can see the thickness of s1...s15 is 0.025, but some part of the internal cell zone seems erased..would appreciate your contributions. for some reason, i can't attach files in private message. https://www.dropbox.com/s/86zdqugxi6...htMRF.zip?dl=0 kind regards Nas |
November 28, 2015, 17:18 |
installing openfoam 2.4.x
#20 |
nasir musa yakubu
Rep Power: 12 |
Hello Bruno, now trying to install the 2.4.x however i keep getting stuck in
step 6 of the installation, when ever i run the command, i get: Code:
parallels@ubuntu:~/OpenFOAM$ source $HOME/OpenFOAM/OpenFOAM-2.4.x/etc/bashrc WM_NCOMPPROCS=16 bash: /opt/OpenFOAM-2.4.x/bin/foamEtcFile: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory bash: /opt/OpenFOAM-2.4.x/etc/config/settings.sh: No such file or directory bash: /opt/OpenFOAM-2.4.x/etc/config/aliases.sh: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamEtcFile: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamEtcFile: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamEtcFile: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamEtcFile: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory parallels@ubuntu:~/OpenFOAM$ echo "alias of24x='source \$HOME/OpenFOAM/OpenFOAM-2.4.x/etc/bashrc $FOAM_SETTINGS'" >> $HOME/.bashrc parallels@ubuntu:~/OpenFOAM$ and afterwards, i get the following Code:
parallels@ubuntu:~$ of24x bash: /opt/OpenFOAM-2.4.x/bin/foamEtcFile: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory bash: /opt/OpenFOAM-2.4.x/etc/config/settings.sh: No such file or directory bash: /opt/OpenFOAM-2.4.x/etc/config/aliases.sh: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamEtcFile: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamEtcFile: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamEtcFile: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamEtcFile: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory bash: /opt/OpenFOAM-2.4.x/bin/foamCleanPath: No such file or directory parallels@ubuntu:~$ Also wondering if i should try the version 3, which i just realised, has been released. thanks |
solidDisplacementFoam vs. solidEquilibriumDisplacementFoam | Tobi | OpenFOAM Running, Solving & CFD | 6 | September 23, 2021 03:26 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] Multiple outside loops error | badoumba | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2019 07:52 |
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs | Pier84 | OpenFOAM Installation | 4 | June 18, 2016 16:22 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
