[snappyHexMesh] Multiblock input from blockMEsh for sHM |
May 28, 2020, 05:46 |
BastiL
Rep Power: 20 |
Hello all,
I have a background mesh for sHM created in blockMesh. It is structured and consists of three blocks. To use this in sHM I have to merge the "interfaces" between the blocks to form one continuous input background-mesh. This is an issue, simply due to the size of the patches to merge (approx. 450000 nodes each of the two pairs). Both stitchMesh and mergePatchPairs in blockMesh are running for hours and I am not sure about the result yet. I thought about defining three "locationsInMesh" in sHM, one inside each block. I guess this will work, the questions is if the resulting mesh after sHM-run is merged or not? (means will the resulting mesh consist of one part as required or will it still consist of three parts). I think still three. Is there any other option to think about? Thanks. Last edited by bastil; May 28, 2020 at 08:37. |
May 28, 2020, 10:38 |
Franco
Rep Power: 6 |
hello,
why are you using three blocks in blockmesh? -to have better refiment in part of the final mesh? if thats so, it might be better to define a block that is the size of the three and use a region with a box defined in gemoetry inside snappy to refine the region you want to be refined. -to have a "L-like" backgound mesh? if that is the case, i recomend to simple use a big block as snappy will erase the rest of the mesh and sincerely (i dont know the size of your blockmesh) but is usually super fast, it wouldnt matter for the complete case to do the L-like or a bigger block (at least in my experience) I can not imagine another case, hope it helps |
May 28, 2020, 12:04 |
Luis Eduardo
Rep Power: 15 |
Hi Bastil,
Can you send a picture of you blockMesh mesh? I have been working with multiple blocks in blockMesh without any issue (attached figure). One thing you have to make sure is that the vertices and faces are well defined, if the interface of the blocks is well defined, then you don't have to manually merge them (the face of one block has to have the same vertices from the face in the other block, in the correct order). Best Regards, Luis |
May 28, 2020, 13:31 |
BastiL
Rep Power: 20 |
thanks for the hints. For clarification: - I have a "U" shaped geometry I want to mesh. As I am completely at the limit with RAM I can't put the geometry inside one big box without reducing block mesh cell count by approx. two which will end in a too coarse mesh. - From all my experience refinement in blockMesh is much less memory expensive than doing refinement in sHM (factor of two approx.). Therefore. no refinement is done in sHM, only snapping and layers. I start with an initial fine mesh. - As my blockMesh is somehow U-shaped to fit the geometry my blocks do not completely match (I have conformal nodes due to same refinement but can not share all the four face vertices) One other option I am thinking of is creating one large block in blockMesh (I have the RAM for this) and remove the unrequired parts before starting sHM. Hope my explanation helps. I can post an image next week. |
May 29, 2020, 17:46 |
Luis Eduardo
Rep Power: 15 |
Hi Bastil,
A U-shaped geometry can definitely be generated in blockMesh, maybe a figure of your geometry and the mesh you got would help, it may be something specific from your problem that I'm not quite understanding. How much RAM do you have? What is the number of elements you are getting your mesh? |
May 30, 2020, 05:09 |
#6 | ||
BastiL
Rep Power: 20 |
Agree. I will post a picture next week. I get the U-shaped geometry without merged patches. As soon as turning on "mergePatchPairs" blockMesh (and also stitchMesh as the alterantive) run for hours so far without result. Note that the patches between block 1 and block 2 and block 2 and block 3 have arround 450000 nodes to be merged each. Seems to be to much for mergePatchPairs and stichMesh. Quote:
128 GB. I can create a blockMesh of up to 100 Million elements. However, from what I figured out, sHM requires about 2.2 times the memory. Therefore, the maximum number of hex elements as a background mesh that I can have in snappy is approx. 45 million cells. To encapsulate my geomety with a sufficant resolution in ONE block I need about 95 million cells in blockMesh, to much to handle in sHM afterwards. Doing it in THREE blocks will reduce the amount of required background cells to approx. 40 million cells. I tried I can chandle it in sHM but so far I have unconnected blocks there .... |
June 3, 2020, 11:17 |
Luis Eduardo
Rep Power: 15 |
Hi Bastil,
Did you manage to make it work? Could you also share you blockMeshDict file? I don't have the amount of RAM that you have, but I can try a simplified mesh... |
June 3, 2020, 11:36 |
#8 | |
Franco
Rep Power: 6 |
a way easier way to do it (at least IMO...) is to do the background mesh in salome and then you export it to univ mesh and transform it to openfoam |
June 4, 2020, 04:00 |
#9 |
BastiL
Rep Power: 20 |
Hello all,
here is the blockMeshDict: Code:
convertToMeters 1; vertices ( (-124.9875 -63.4875 -0.05) // 0 ( 124.9875 -63.4875 -0.05) // 1 ( 124.9875 63.4875 -0.05) // 2 (-124.9875 63.4875 -0.05) // 3 (-124.9875 -63.4875 0.45) // 4 ( 124.9875 -63.4875 0.45) // 5 ( 124.9875 63.4875 0.45) // 6 (-124.9875 63.4875 0.45) // 7 ( -76.9875 -63.4875 0.45) // 8 ( -76.9875 -15.4875 0.45) // 9 (-124.9875 -15.4875 0.45) // 10 (-124.9875 -63.4875 0.95) // 11 ( -76.9875 -63.4875 0.95) // 12 ( -76.9875 -15.4875 0.95) // 13 (-124.9875 -15.4875 0.95) // 14 ( 76.9875 63.4875 0.45) // 15 ( 76.9875 15.4875 0.45) // 16 ( 124.9875 15.4875 0.45) // 17 ( 124.9875 63.4875 0.95) // 18 ( 76.9875 63.4875 0.95) // 19 ( 76.9875 15.4875 0.95) // 20 ( 124.9875 15.4875 0.95) // 21 ); blocks ( hex (0 1 2 3 4 5 6 7) block1 (3333 1693 8) simpleGrading (1 1 1) hex (4 8 9 10 11 12 13 14) block2 (640 640 8) simpleGrading (1 1 1) hex (6 15 16 17 18 19 20 21) block3 (640 640 8) simpleGrading (1 1 1) ); edges ( ); boundary ( topPatch { type patch; faces ( (4 5 6 7) ); } inletPatch { type patch; faces ( (4 8 9 10) ); } outletPatch { type patch; faces ( (6 17 16 15) ); } walls { type wall; faces ( (0 1 5 4) (1 2 6 5) (0 1 2 3) (2 3 7 6) (0 3 7 4) (4 8 12 11) (8 9 13 12) (9 10 14 13) (10 4 11 14) (11 12 13 14) (16 17 21 20) (17 6 18 21) (6 15 19 18) (15 16 20 19) (18 19 20 21) ); } ); mergePatchPairs ( // (topPatch inletPatch) // (topPatch outletPatch) ); |
June 4, 2020, 04:34 |
#10 |
BastiL
Rep Power: 20 |
June 4, 2020, 08:24 |
#11 |
BastiL
Rep Power: 20 |
Ok workaround that seems to run:
1. Create one uniform large block in blockMesh (Memory for this is available, but not enough RAM for using this as a background mesh) 2. Use "setSet" and "subsetMesh" to cut out the U-Shape out of the large mesh block (will reduce the mesh size and remove not required cells in the background mesh before starting sHM). Now we have the desired U-shaped background mesh (without the need to merge any patches) 3. Use this as background mesh for sHM. |
June 4, 2020, 12:12 |
#12 |
Luis Eduardo
Rep Power: 15 |
Hi Bastil,
And how does your geometry looks inside this blockMesh? I'm insisting on this because it may be possible to create this geometry in your blockMeshDict (if it is not a complex geometry...) and generate the mesh only inside that region, this way you would save millions of cells. Your blockMeshDict also worked for me. Best Regards, Luis |
June 4, 2020, 14:28 |
#13 | |
BastiL
Rep Power: 20 |
No way. The geometry is highly complex. Did blockMesh also run with the two "mergePatchPair" lines uncommented? This is were the trouble starts for me. However I need a connected Background Mesh as far as I know. |
June 5, 2020, 11:24 |
#14 |
Luis Eduardo
Rep Power: 15 |
Actually, it runs Ok for a simplified mesh, but the checkMesh points 2 fails:
Mesh stats points: 7204107 faces: 18414756 internal faces: 15806152 cells: 5520000 faces per cell: 6.19944 boundary patches: 2 point zones: 0 face zones: 0 cell zones: 3 Overall number of cells of each type: hexahedra: 5167781 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 352219 Breakdown of polyhedra by number of faces: faces number of cells 5 435 6 75 7 36739 8 26634 9 142008 10 146328 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology topPatch 1200604 1363736 multiply connected (shared edge) walls 1408000 1412449 ok (non-closed singly connected) <<Writing 2220 conflicting points to set nonManifoldPoints Checking geometry... Overall domain bounding box (-124.988 -63.4875 -0.05) (124.988 63.4875 0.95) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) ***Boundary openness (2.19193e-18 -8.85885e-18 0.0672382) possible hole in boundary description. ***Open cells found, max cell openness: 0.984424, number of open cells 174556 <<Writing 174556 non closed cells to set nonClosedCells Minimum face area = 6.6e-05. Maximum face area = 0.0264505. Face area magnitudes OK. Min volume = 0.00259327. Max volume = 0.00377864. Total volume = 18233.8. Cell volumes OK. Mesh non-orthogonality Max: 61.1557 average: 8.61417 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.732837 OK. Coupled point location match (average 0) OK. Failed 2 mesh checks. As you said that it's a highly complex geometry, then go to an external mesh generator, SHM will give you a hard time for the mesh size you want to generate... I thought it was a U-shaped geometry. If you are dealing with pipes, you can still make it work in blockMesh. It's not an easy task, but it can be done. Good luck! |
June 9, 2020, 17:35 |
#15 |
Luis Eduardo
Rep Power: 15 |
Correct foamfile header for input file with mixed quantities (any version of OF) | deepbandivadekar | OpenFOAM Running, Solving & CFD | 3 | February 15, 2021 05:10 |
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 7 | August 25, 2020 19:15 |
[OpenFOAM] Paraview 3.98 - errors when saving geometry file | pajot | ParaView | 1 | September 28, 2013 10:45 |
[blockMesh] set of xyz data in blockMesh | psk | OpenFOAM Meshing & Mesh Conversion | 12 | August 27, 2013 08:37 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 11:59 |
