[snappyHexMesh] Impossible to add layers in SnappyHexMesh |
March 25, 2019, 11:32 |
Rep Power: 7 |
Hello everyone,
I have a big problem with the function "AddLayer" in SnappyHexMesh. I tried several parameters but the layers don't appear in ParaView, even if the calculation takes them into account. I increased the number of layers, the number of iterations... but nothing work, except a very few layers (picture). Can someone help me please ? Thank you. Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.0 | | \\ / A nd | Web: http://www.openfoam.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; // true; snap true; // true; addLayers true; // true; geometry { wall.stl {type triSurfaceMesh; name wall;} sphere3 {type searchableSphere; centre (0 0 0); radius 500;} sphere4 {type searchableSphere; centre (0 0 0); radius 1000;} }; // Settings for the castellatedMesh generation. castellatedMeshControls { maxLocalCells 1000000; maxGlobalCells 10000000; minRefinementCells 5; nCellsBetweenLevels 2; //6 refinementSurfaces { wall { level (2 3); //level (3 4) } } refinementRegions { sphere3 { mode inside; levels ((500 3)); } sphere4 { mode inside; levels ((800 2)); } } resolveFeatureAngle 20; locationInMesh (0 500 0); features ( { file "wall.eMesh"; level 3; } ); allowFreeStandingZoneFaces false; } // Settings for the snapping. snapControls { nSmoothPatch 4; tolerance 10; nSolveIter 80; nRelaxIter 8; } // Settings for the layer addition. addLayersControls { relativeSizes true; layers{ wall { nSurfaceLayers 8; } } expansionRatio 1.2; finalLayerThickness 0.3; //thickness 100; minThickness 0.005; nGrow 0; featureAngle 30; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 1.0;//0.5 maxThicknessToMedialRatio 1.0;//0.3 minMedianAxisAngle 130; nBufferCellsNoExtrude 0; nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { maxNonOrtho 70; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minFlatness 0.5; minVol -1e13; minArea -1; minTwist 0.05; minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; minTetQuality 1e-30; } // Advanced // Flags for optional output // 0 : only write final meshes // 1 : write intermediate meshes // 2 : write volScalarField with cellLevel for postprocessing // 4 : write current intersections as .obj files debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1E-6; // ************************************************************************* // Capture du 2019-03-25 15-38-59.jpg Capture du 2019-03-25 17-31-27.jpg |
March 25, 2019, 12:01 |
Rep Power: 7 |
Up ^^ guys
March 26, 2019, 02:32 |
Rep Power: 7 |
Up the topic
March 27, 2019, 17:00 |
Daniel P. Combest
Layers are most easily added in regions where near wall cells have an aspect ratio of unity. It looks like your near surface cells have a really large aspect ratio.
March 27, 2019, 17:09 |
Rep Power: 7 |
Hi chegdan, you are right, I understood the problem this morning and I fixed it ! Now I have layers around all my surface ^^.
[snappyHexMesh] Snappy add layers failed | mqsim | OpenFOAM Meshing & Mesh Conversion | 1 | January 24, 2021 15:02 |
[snappyHexMesh] snappyHexMesh not adding layers to a solid | jet_engine | OpenFOAM Meshing & Mesh Conversion | 0 | June 3, 2016 08:25 |
[snappyHexMesh] snappyHexMesh - layers in 3d pipe bifurcation | nihil | OpenFOAM Meshing & Mesh Conversion | 13 | April 9, 2013 08:32 |
[snappyHexMesh] snappyHexMesh : Layers on patches | Nucleophobe | OpenFOAM Meshing & Mesh Conversion | 0 | October 11, 2012 17:34 |
[snappyHexMesh] Add additional boundary layers to complex stl surface | tobijingles | OpenFOAM Meshing & Mesh Conversion | 1 | October 26, 2011 10:45 |
