[Commercial meshers] Problem with element's ID output |
April 2, 2019, 04:58 |
Daniel Herranz
Rep Power: 7 |
Good morning,
I am doing an external aerodynamic simulation of a 3D airfoil. I Meshes the airfoil with shells and 10 boundary layers (volumes), and then make volumes for the air domain. The simulation is running well as I did a lot of simulations by now. Now, the problem... I wanted to get an output .txt file of Element ID | Pressure value to input it in abaqus. But I am not able as the faces output by ANSA does not match the element ID of the mesh file. The mesh has 1.05 million elements and the faces at openFOAM files start numbering a 2.2million. How can I make them correspond to the original mesh file ID's? Thanks. |
ansa, faces, openfoam |
Problem with torque output from a turbine simulation. | pa-dundas | FLUENT | 5 | July 17, 2022 05:27 |
Parameter Output Problem | Sabayonetta | FLUENT | 0 | May 11, 2015 02:53 |
DPM Output Problem (Again...) | DLINSA | Fluent UDF and Scheme Programming | 1 | March 16, 2012 00:45 |
CFX-5.7 MPICH Parallel Problem (Output of Results) | James Date | CFX | 7 | February 15, 2005 16:03 |
ICEM5 Hexa output problem | Pete | CFX | 9 | September 16, 2004 18:33 |
