attempt to read beyond EOF file
Thanks for the help
[Moderator note: The following was what was possible to recover from Google's cache, after the OP deleted the post and left the above sentence.] I have generated a blockMeshdict file to run on OpenFOAM but receive an error: --> FOAM FATAL IO ERROR: attempt to read beyond EOF file: ... |
I think your problem comes from the fact that one of your boundary patch names has a space. I suggest you change "Leading Edge" to "Leading_Edge" or "LeadingEdge" and see if that solves your issues. Cheers, Antimony |
