Arman_N |
April 16, 2019 13:55 |
snappyHexMesh does not create any mesh except one for the reference cell
2 Attachment(s)
Hello to all,
I am somewhat new to CFD modeling and mesh generation.
Basically, I am trying to generate a mesh for a simple porous geometry and have created an .stl file for it (file attached below). I have checked it with surfaceCheck and it says that the surface is closed.
However, when I run the snappyHexMesh command, it removes all the background mesh except for the cell which contains the point specified by locationInMesh in snappyHexMeshDict (figure attached below). It seems that somehow the rest of the sections of the mesh are unreachable and hence it removes them all.
I would really appreciate if anyone could help me find out what I am doing wrong and how to solve this since it seems to be a trivial problem.
Many thanks,
Arman
snappyHexMeshDict:
| \\ / O peration | Version: 4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh true;
snap false;
addLayers false;
geometry
all.stl
type triSurfaceMesh;
name all;
castellatedMeshControls
maxLocalCells 500000;
maxGlobalCells 2000000;
minRefinementCells 0;
maxLoadUnbalance 0.10;
nCellsBetweenLevels 1;
features
// file "all.eMesh";
// level 0;
refinementSurfaces
all
level (0 0);
resolveFeatureAngle 30;
refinementRegions
locationInMesh (-0.00123 0.00003 0);
allowFreeStandingZoneFaces true;
snapControls
nSmoothPatch 3;
tolerance 1.0;
nSolveIter 300;
nRelaxIter 5;
nFeatureSnapIter 10;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap false;
addLayersControls
relativeSizes true;
layers
//"flange_.*"
// nSurfaceLayers 1;
expansionRatio 1.0;
finalLayerThickness 0.3;
minThickness 0.1;
nGrow 0;
featureAngle 0;
nRelaxIter 5;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedianAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
nRelaxedIter 20;
meshQualityControls
#include "meshQualityDict"
relaxed
maxNonOrtho 80;
maxBoundarySkewness 2;
maxInternalSkewness 2;
maxSkewness 2;
maxConcave 80;
minFlatness 0.5;
minVol 0;
minTetQuality 1e-10;
minArea 0;
minTwist 0.5;
minDeterminant 0.25;
minFaceWeight 0.2;
minVolRatio 0.5;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
writeFlags
scalarLevels
layerSets
layerFields
debug 0;
mergeTolerance 1E-6;
snappyHexMesh output:
| \\ / O peration | Version: v1806 |
| \\ / A nd | Web: www.OpenFOAM.com |
Build : v1806
Arch : "LSB;label=32;scalar=64"
Exec : snappyHexMesh
Date : Apr 16 2019
Time : 17:50:34
Host : "Arman"
PID : 16369
I/O : uncollated
Case : /media/arman/EDU/ProSoft/Installed/OpenFOAM/GeoChemFoam/run/validationCase/mesh_all
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM Warning :
From function static Foam::IOstreamOption::compressionType Foam::IOstreamOption::compressionEnum(const Foam::word&)
in file db/IOstreams/IOstreams/IOstreamOption.C at line 86
Unknown compression specifier 'uncompressed', assuming no compression
Create mesh for time = 0
Read mesh in = 0.03 s
Overall mesh bounding box : (-0.0018 -0.00055 -2.5e-05) (0.0018 0.00055 2.5e-05)
Relative tolerance : 1e-06
Absolute matching distance : 3.76464e-09
Reading refinement surfaces.
Read refinement surfaces in = 0.01 s
Reading refinement shells.
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
For geometry all.stl detected 0 uncached triangles out of 5000
Checked shell refinement in = 0.01 s
Reading features.
Read features in = 0 s
Determining initial surface intersections
Edge intersection testing:
Number of edges : 25532
Number of edges to retest : 25532
Number of intersected edges : 8130
Calculated surface intersections in = 0.07 s
Initial mesh : cells:6336 faces:25532 points:13050
Cells per refinement level:
0 6336
Adding patches for surface regions
Patch Type Region
all:
1 wall all
Added patches in = 0 s
Number of edges to retest : 0
Selecting decompositionMethod none [1]
Refinement phase
Found point (-0.00123 3e-05 0) in cell 3334 on processor 0
Surface refinement iteration 0
Marked for refinement due to surface intersection : 0 cells.
Determined cells to refine in = 0.03 s
Selected for refinement : 0 cells (out of 6336)
Stopping refining since too few cells selected.
Removing mesh beyond surface intersections
Setting cellZones according to locationsInMesh:
cellZone : none
For cellZone none found point (-0.00123 3e-05 0) in global region 1 out of 17 regions.
Keeping all cells containing inside points
Selected for keeping : 6336 cells.
cellZone : none
Shell refinement iteration 0
Marked for refinement due to distance to explicit features : 0 cells.
Marked for refinement due to refinement shells : 0 cells.
Determined cells to refine in = 0.13 s
Selected for internal refinement : 0 cells (out of 6336)
Dangling coarse cells refinement iteration 0
Determined cells to refine in = 0 s
Refinement transition refinement iteration 0
Splitting mesh at surface intersections
Introducing baffles for 8130 faces that are intersected by the surface.
cellZone : none
Number of edges : 26454
Number of edges to retest : 18630
Number of intersected edges : 9052
Created baffles in = 0.11 s
After introducing baffles : cells:6336 faces:26454 points:13050
0 6336
Introducing baffles to block off problem cells
markFacesOnProblemCells : marked 6752 additional internal faces to be converted into baffles.
Analyzed problem cells in = 0.01 s
Introducing baffles to delete problem cells.
Number of edges : 33206
Number of edges to retest : 21695
Created baffles in = 0.05 s
After introducing baffles : cells:6336 faces:33206 points:13050
0 6336
cellZone : none
For cellZone none found point (-0.00123 3e-05 0) in global region 1956 out of 3626 regions.
Number of edges to retest : 25376
Remove unreachable sections of mesh
Keeping all cells containing points 1((-0.00123 3e-05 0))
Selected for keeping : 1 cells.
Number of edges : 6
Number of intersected edges : 2
Split mesh in = 0.14 s
After subsetting : cells:1 faces:6 points:8
0 1
Introducing zones for interfaces
cellZone : none
For cellZone none found point (-0.00123 3e-05 0) in global region 0 out of 1 regions.
Setting faceZones according to neighbouring cellZones:
Number of edges : 6
Handling cells with snap problems
Introducing baffles for 2 faces that are intersected by the surface.
cellZone : none
Number of edges : 6
Number of edges to retest : 6
Created baffles in = 0 s
After introducing baffles : cells:1 faces:6 points:8
0 1
markFacesOnProblemCells : marked 0 additional internal faces to be converted into baffles.
Analyzed problem cells in = 0 s
0 1
cellZone : none
Number of edges : 6
Split mesh in = 0 s
0 1
Merge free-standing baffles
freeStandingBaffles : detected 0 free-standing baffles out of 0
Detected free-standing baffles : 0
Merged free-standing baffles in = 0 s
dupNonManifoldPoints : Found : 0 non-manifold points (out of 8)
Detected unsplittable baffles : 0
Merge refined boundary faces
Merging 0 sets of faces.
No faces merged ...
Merging all points on surface that
- are used by only two boundary faces and
- make an angle with a cosine of more than 0.707107.
No straight edges simplified and no points removed ...
Refined mesh : cells:1 faces:6 points:8
0 1
Writing mesh to time 1
Wrote mesh in = 0 s.
Mesh refined in = 0.46 s.
Checking final mesh ...
Checking faces in error :
non-orthogonality > 65 degrees : 0
faces with face pyramid volume < 0 : 0
faces with face-decomposition tet quality < 1e-10 : 0
faces with concavity > 80 degrees : 0
faces with area < 0 m^2 : 0
faces with skewness > 2 (internal) or 2 (boundary) : 0
faces with interpolation weights (0..1) < 0.2 : 0
faces with volume ratio of neighbour cells < 0.5 : 0
faces with face twist < 0.5 : 0
faces on cells with determinant < 0.25 : 0
Finished meshing without any errors
Finished meshing in = 0.59 s.
End
Attachment 69447
Attachment 69448
