[Gmsh] Trying to convert an already generated gmsh to OpenFOAM
Like Tree2Likes
  • 2 Post By mzzmrt
Old   May 7, 2019, 03:08
Default Trying to convert an already generated gmsh to OpenFOAM
Ehsan Asgari
syavash is on a distinguished road
Dear mates,
I am new to Gmsh. I have tried to convert an existing 3-D gmsh file to OpenFOAM format using gmshToFoam utility. I was successful in opening the grid file and I have assigned names to the 2-D surfaces using Physical Groups-->Add. Also, I specified name to the volume. I have attached the geo file for more information (I have renamed it to txt so I can upload it!).
However, when I try to convert the modified gmsh file using gmshToFoam utility, I get messages like the following:
Unhandled element 12 at line ...
And in the end I have the following error message:
No cells read from file "test4"
Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)?
Perhaps you have not exported the 3D elements?
file: test4 at line 620821.
    From function readCells(..)
    in file gmshToFoam.C at line 726.
FOAM exiting
Unfortunately, the size of the initial gmsh file is large, so I put the link to the file below:
http://www.as.dlr.de/hiocfd/c3.6_gri...x32_p2.msh.bz2
The question is what I am doing wrong? Could anyone please tell me where the problem lies?
Regards,
Syavash
File Type: txt test4.txt (298 Bytes, 4 views)
syavash is offline   Reply With Quote
Old   May 7, 2019, 05:16
mzzmrt is on a distinguished road
This may be a solution unless you don't have the original *.geo script of this mesh;
1. Open the file (phill_64x32x32_p2_gmsh) with gmsh
2. Create a 3D mesh with it (on the left menu: mesh>3D)
3. File>export test.mesh (as version 2 ascii format)
4. put this *.msh in the OpenFOAM case directory
5. run gmshToFoam test.msh
6. run autoPatch 80 - overwrite
7. run paraFoam to check the pacth names
8. configure the boundary, nut, U, P, etc. files according to this patch names (or change them in the boundary file) and types...
sourav90 and ifrit54 like this.
mzzmrt is offline   Reply With Quote
Old   May 7, 2019, 08:46
Ehsan Asgari
Wow! Thank you. The creation of the 3-D mesh did the trick.
Kind Regards,
Syavash
Old   March 11, 2020, 11:15
Arash
arashgmn is on a distinguished road
This won't identify the interior surfaces (for instance, when there are sliding sub-domains, the intersection can be defined as an interior physical group which is totally invisible to autoPatch.)
arashgmn is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 2 Today 01:18
Getting Started with OpenFOAM wyldckat OpenFOAM 24 October 2, 2019 22:35
Can't convert my mesh created in Gmsh to OpenFOAM Crystal 95 OpenFOAM 1 May 2, 2018 11:42
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
