[snappyHexMesh] snappyHexMesh failing silently
Old   May 16, 2019, 11:07
Default snappyHexMesh failing silently
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
Hello.
I have this simple setup with snappyHexMesh. Snappy fails silently before starting snapping. I'm afraid it might also be a system issue (I work on Windows subsystem for Linux).
These are the few last lines from snappy output:
Checking initial mesh ...
Checking faces in error :
    non-orthogonality > 65  degrees                        : 0
    faces with face pyramid volume < 1e-15                 : 0
    faces with face-decomposition tet quality < 1e-15      : 0
    faces with concavity > 80  degrees                     : 0
    faces with skewness > 4   (internal) or 20  (boundary) : 0
    faces with interpolation weights (0..1)  < 0.05        : 0
    faces with volume ratio of neighbour cells < 0.01      : 0
    faces with face twist < 0.02                           : 0
    faces on cells with determinant < 0.001                : 0
Detected 0 illegal faces (concave, zero area or negative cell pyramid volume)
Checked initial mesh in = 0.11 s
Smoothing patch points ...
Smoothing iteration 0
Found 146 non-manifold point(s).
Scaling iteration 0
Moving mesh using displacement scaling : min:1  max:1
jnejc@JNEJC:/mnt/d/OpenFOAM/$
Could someone please run the attached case and see if it works? I have run out of ideas for debugging this one.
Thanks!
www.damogranlabs.com
kandelabr is offline   Reply With Quote
Old   May 17, 2019, 04:48
kandelabr's Avatar
Nejc
I figured it out.
There's nothing wrong with geometry, blockMesh, snappyHexMesh or anything else.
In controlDict there was
HTML Code:
deltaT 0;
I have no idea where this number came from but it caused my strange non-error.
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[snappyHexMesh] snappyHexMesh failing to snap ("did not find surface within...") Jaworski.Mike OpenFOAM Meshing & Mesh Conversion 7 December 2, 2019 21:13
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] snappyHexMesh not snapping perfectly to surface and failing checkMesh Greg Givogue OpenFOAM Meshing & Mesh Conversion 5 February 28, 2011 12:43
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
