[blockMesh] Meshing this plate with cyclic boundary conditions |
June 5, 2019, 08:18 |
Thomas
Rep Power: 7 |
Hello everyone
I want to mesh a thin plate in the x-y plane and apply cyclic/periodic boundary conditions for each of my internal fields. Then I would like to use a compressible solver dbnsFoam (p, T, U) to move a vortex. I am trying to reproduce the results in that paper: https://dl.acm.org/citation.cfm?id=3067565, section 7.5. Here is my 'blockMeshDict' Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) (10 0 0) (10 10 0) (0 10 0) (0 0 1) (10 0 1) (10 10 1) (0 10 1) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { faces ((0 4 7 3)); type cyclic; neighbourPatch outlet; } outlet { faces ((2 6 5 1)); type cyclic; neighbourPatch inlet; } bottom { faces ((1 5 4 0)); type cyclic; neighbourPatch top; } top { faces ((3 7 6 2)); type cyclic; neighbourPatch bottom; } left { faces ((0 3 2 1)); type wall;//cyclic; //neighbourPatch right; } right { faces ((4 5 6 7)); type wall;//cyclic; //neighbourPatch left; } ); mergePatchPairs ( ); // ************************************************************************* // Code:
Creating block mesh from "./shockTube/constant/polyMesh/blockMeshDict" Creating curved edges Creating topology blocks Creating topology patches Creating block mesh topology Segmentation fault (core dumped) Can you help me figure out what is wrong in this piece of code ? Thanks Thomas |
blockmesh, cyclic, dbns, foam-extend, openfoam |
Display Modes | |
Cyclic boundary condition in foam-extend 4.0 | rellumeister | OpenFOAM Pre-Processing | 2 | March 3, 2020 09:03 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Flat plate and Boundary conditions | Ravenn | FLUENT | 1 | March 10, 2013 19:39 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
