[blockMesh] Editing blockMeshdict in IBM tutorials |
June 25, 2019, 06:45 |
Varun Gadre
I edited the blockMeshDIct of Pitching plate tutorial in Immersed Boundary Method of Foam Extend 4.0 by changing the number of cells. But after editing I am not able to run this tutorial due to the following error
--> FOAM FATAL ERROR: Can't find nearest triSurface point for cell 124410, (0.000214286 -0.00225 0.0005). Hit data = 0 (6.95328e-310 6.92949e-310 2.78653e-321) -1 From function immersedBoundaryFvPatch::makeIbPointsAndNormals() const in file immersedBoundaryFvPatch/immersedBoundaryFvPatch.C at line 1037. FOAM aborting Aborted (core dumped) I need to know what other changes I need to do along with changing the number of points to properly run the tutorial. |
blockmeshdict, foam extend 4.0, immersed boundary method, tutorial |
Current status of IBM in OpenFOAM | quarkz | OpenFOAM Programming & Development | 2 | January 29, 2020 03:57 |
[blockMesh] Creating an axisymmetric piston cylinder in blockMeshDict | foadsf | OpenFOAM Meshing & Mesh Conversion | 9 | August 23, 2018 07:54 |
[blockMesh] Tutorials lacking blockMeshDict | DiracRules | OpenFOAM Meshing & Mesh Conversion | 6 | May 9, 2018 15:19 |
Why a different enthalpy of water is used in the tutorials? | yun_cn | Fluent Multiphase | 0 | November 2, 2017 04:35 |
[BEGINNER] Problems running tutorials (incompressible) in OF 2.xx | Jaro | OpenFOAM Running, Solving & CFD | 8 | March 16, 2016 07:27 |
