mzhang |
June 14, 2019 05:01 |
Usage of locationsInMesh
Hi, guys,
I am trying to solve an internal flow problem, and I wish to seperate the mesh for the flow channel into two regions with a surface to ease the post processing.
What I did is that I defined two points respectively located in the two regions with locationsInMesh, but snappyHexMesh returned with an error:
keyword locationInMesh is undefined in dictionary "/home/mzhang/openfoam6/pROJECTS/testlocationsinmesh/system/snappyHexMeshDict.castellatedMeshControls"
I wonder if any of you would please be able to identify where the problem is?
Thanks,
Mingzi
FoamFile
version 2.0;
format ascii;
class dictionary;
//location system;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers true;
geometry
inlet.stl
type triSurfaceMesh;
name inlet;
appendRegionName false;
necksurface.stl
name necksurface;
outlet1.stl
name outlet1;
outlet2.stl
name outlet2;
wall.stl
name wall;
features
file "inlet_line.eMesh";
levels ((0.0 0));
refineFeatureEdgesOnly false;
file "necksurface_line.eMesh";
levels ((0.0 0));
file "outlet1_line.eMesh";
levels ((0.0 0));
file "outlet2_line.eMesh";
levels ((0.0 0));
file "wall_line.eMesh";
levels ((0.0 0));
refinementSurfaces
inlet
level ( 2 4 );
necksurface
level ( 2 4 );
outlet1
level ( 2 4 );
outlet2
level ( 2 4 );
wall
level ( 4 5 );
refinementRegions
//locationInMesh (0.0527 0.0482 0.0415);
locationsInMesh
(( 0.0527 0.0482 0.0415 ) intraIA)
(( 0.0564 0.0558 0.0386 ) intraPA)
maxLocalCells 10000000;
maxGlobalCells 20000000;
minRefinementCells 0;
nCellsBetweenLevels 1;
resolveFeatureAngle 80.0;
allowFreeStandingZoneFaces true;
planarAngle 30.0;
maxLoadUnbalance 0.1;
snapControls
nSolveIter 30;
nSmoothPatch 3;
tolerance 1.0;
nRelaxIter 5;
nFeatureSnapIter 10;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap false;
addLayersControls
layers
relativeSizes true;
expansionRatio 1.0;
finalLayerThickness 0.3;
minThickness 0.25;
nGrow 0;
featureAngle 130.0;
slipFeatureAngle 30.0;
nRelaxIter 5;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedialAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
nRelaxedIter 20;
writeVTK false;
noErrors false;
layerRecovery 1;
growZoneLayers false;
projectGrownUp 0.0;
meshQualityControls
maxNonOrtho 65.0;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80.0;
minFlatness 0.5;
minVol 1.0E-21;
minTetQuality 1.0E-15;
minArea -1.0;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1.0;
nSmoothScale 4;
errorReduction 0.75;
relaxed
maxNonOrtho 75;
debug 0;
mergeTolerance 1.0;
autoBlockMesh false;
