[blockMesh] remove internal face automaticaly created and which don't have any physical meaning |
June 28, 2019, 08:31 |
Rep Power: 6 |
Hi all.
I'm trying to mesh a canal which contain an little obstacle (area with no mesh) here is a very rough sketch of how I mesh it with 10 blocks : At the junctions betweens some groups of hex blocks (in purple), blockMesh is generating some faces with are put in a defaultface patch that I don't want: here is a picture of the mesh: the horizontal red faces are my defaultFace patch ( the vertical red faces are a patch were I'll apply a heating boudary condition) Why does blockMesh is doing this ? I've no duplicated nodes (i've checked with gmsh). Can someone give me some advices me to cope with this ? I've heard about stitchMesh and topoSet but i don't see how I can use them to remove theses face from my mesh. Here is my blockMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0. 0. 0.) //0 (1. 0. 0.) //1 (1. 0. 1.) //2 (0. 0. 1.) //3 (0. 2.5 0.) //4 (1. 2.5 0.) //5 (1. 2.5 1.) //6 (0. 2.5 1.) //7 (0. 7.5 0.) //8 (1. 7.5 0.) //9 (1. 7.5 1.) //10 (0. 7.5 1.) //11 (0. 10. 0.) //12 (1. 10. 0.) //13 (1. 10. 1.) //14 (0. 10. 1.) //15 (0.6 4.5 0.)//16 boite chauffante face bas (0.75 4.5 0.)//17 (0.75 4.5 1.)//18 (0.6 4.5 1.)//19 (0.6 5.5 0.)//20 boite chauffante haut (0.75 5.5 0.)//21 (0.75 5.5 1.)//22 (0.6 5.5 1.)//23 (0. 4.5 0.)//24 limite basse boite chauffante pour bloc 2 (1. 4.5 0.)//25 (1. 4.5 1.)//26 (0. 4.5 1.)//27 (0. 5.5 0.)//28 limite haute boite chauffante pour bloc 3 et 4 (1. 5.5 0.)//29 (1. 5.5 1.)//30 (0. 5.5 1.)//31 (0.6 2.5 0.)//32 boite chauffante tout en bas (0.75 2.5 0.)//33 (0.75 2.5 1.)//34 (0.6 2.5 1.)//35 (0.6 7.5 0.)//36 boite chauffante tout en haut (0.75 7.5 0.)//37 (0.75 7.5 1.)//38 (0.6 7.5 1.)//39 ); blocks ( hex (0 1 5 4 3 2 6 7) (20 30 1) simpleGrading (1 1 1)//1 hex (33 5 25 17 34 6 26 18) (5 24 1) simpleGrading (1 1 1)//2 hex (32 33 17 16 35 34 18 19) (3 24 1) simpleGrading (1 1 1)//3 hex (4 32 16 24 7 35 19 27) (12 24 1) simpleGrading (1 1 1)//4 hex (17 25 29 21 18 26 30 22) (5 12 1) simpleGrading (1 1 1)//5 hex (24 16 20 28 27 19 23 31) (12 12 1) simpleGrading (1 1 1)//6 hex (21 29 9 37 22 30 10 38) (5 24 1) simpleGrading (1 1 1)//7 hex (20 21 37 36 23 22 38 39) (3 24 1) simpleGrading (1 1 1)//8 hex (28 20 36 8 31 23 39 11) (12 24 1) simpleGrading (1 1 1)//9 hex (8 9 13 12 11 10 14 15) (20 24 1) simpleGrading (1 1 1)//10 ); edges ( ); boundary ( inlet { type patch; faces ( (0 1 2 3) ); } outlet { type patch; faces ( (14 13 12 15) ); } paroiAdiabatique { type wall; faces ( (7 4 0 3) (15 12 8 11) (9 13 14 10) (29 9 10 30) (25 29 30 26) (5 25 26 6) (1 5 6 2) (22 18 17 21) (21 22 23 20) (16 19 18 17) ); } paroiChaude { type wall; faces ( (11 8 28 31) (31 28 24 27) (27 24 4 7) (20 23 19 16) ); } frontAndBack { type empty; faces ( (6 7 3 2) (19 27 7 35) (18 19 35 34) (26 18 34 6) (23 31 27 19) (30 22 18 26) (39 11 31 23) (38 39 23 22) (10 38 22 30) (14 15 11 10) (4 5 1 0) (24 16 32 4) (16 17 33 32) (17 25 5 33) (28 20 16 24) (21 29 25 17) (8 36 20 28) (36 37 21 20) (37 9 29 21) (12 13 9 8) ); } ); mergePatchPairs ( ); // ************************************************************************* // //(6 5 33 34) here and bellow planes corresponding //(34 33 32 35) to defaultFace //(35 32 4 7) //(10 9 37 38) //(38 37 36 39) //(39 36 8 11) //(9 8 11 10) //(5 4 7 6) |
July 1, 2019, 06:28 |
Rep Power: 15 |
Hi Voulet,
It is a consequence of the way blocks 2,3 4 (on one side) and block 1 (on the other side) meet. To avoid it, what you can do is to split up block 1 into 3 blocks such that block 1a uses some of the same vertices as block 2, block 1b uses some of the same vertices as block 3 and block 1c uses some of the same vertices as block 4. I think this is best illustrated when you look at this modified blockMeshDict. Look particularly at what block 1 has been replaced by in the code below: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0. 0. 0.) //0 (1. 0. 0.) //1 (1. 0. 1.) //2 (0. 0. 1.) //3 (0. 2.5 0.) //4 (1. 2.5 0.) //5 (1. 2.5 1.) //6 (0. 2.5 1.) //7 (0. 7.5 0.) //8 (1. 7.5 0.) //9 (1. 7.5 1.) //10 (0. 7.5 1.) //11 (0. 10. 0.) //12 (1. 10. 0.) //13 (1. 10. 1.) //14 (0. 10. 1.) //15 (0.6 4.5 0.)//16 boite chauffante face bas (0.75 4.5 0.)//17 (0.75 4.5 1.)//18 (0.6 4.5 1.)//19 (0.6 5.5 0.)//20 boite chauffante haut (0.75 5.5 0.)//21 (0.75 5.5 1.)//22 (0.6 5.5 1.)//23 (0. 4.5 0.)//24 limite basse boite chauffante pour bloc 2 (1. 4.5 0.)//25 (1. 4.5 1.)//26 (0. 4.5 1.)//27 (0. 5.5 0.)//28 limite haute boite chauffante pour bloc 3 et 4 (1. 5.5 0.)//29 (1. 5.5 1.)//30 (0. 5.5 1.)//31 (0.6 2.5 0.)//32 boite chauffante tout en bas (0.75 2.5 0.)//33 (0.75 2.5 1.)//34 (0.6 2.5 1.)//35 (0.6 7.5 0.)//36 boite chauffante tout en haut (0.75 7.5 0.)//37 (0.75 7.5 1.)//38 (0.6 7.5 1.)//39 (0.6 0 0) //40 (0.75 0 0) //41 (0.6 0 1) //42 (0.75 0 1) //43 ); blocks ( //hex (0 1 5 4 3 2 6 7) (20 30 1) simpleGrading (1 1 1)//1 hex (0 40 32 4 3 42 35 7) (12 30 1) simpleGrading (1 1 1) //1a hex (40 41 33 32 42 43 34 35) (3 30 1) simpleGrading (1 1 1) //1b hex (41 1 5 33 43 2 6 34) (5 30 1) simpleGrading (1 1 1) //1c hex (33 5 25 17 34 6 26 18) (5 24 1) simpleGrading (1 1 1)//2 hex (32 33 17 16 35 34 18 19) (3 24 1) simpleGrading (1 1 1)//3 hex (4 32 16 24 7 35 19 27) (12 24 1) simpleGrading (1 1 1)//4 hex (17 25 29 21 18 26 30 22) (5 12 1) simpleGrading (1 1 1)//5 hex (24 16 20 28 27 19 23 31) (12 12 1) simpleGrading (1 1 1)//6 hex (21 29 9 37 22 30 10 38) (5 24 1) simpleGrading (1 1 1)//7 hex (20 21 37 36 23 22 38 39) (3 24 1) simpleGrading (1 1 1)//8 hex (28 20 36 8 31 23 39 11) (12 24 1) simpleGrading (1 1 1)//9 hex (8 9 13 12 11 10 14 15) (20 24 1) simpleGrading (1 1 1)//10 ); edges ( ); boundary ( inlet { type patch; faces ( // (0 1 2 3) (0 40 42 3) (40 41 43 42) (41 1 2 43) ); } outlet { type patch; faces ( (14 13 12 15) ); } paroiAdiabatique { type wall; faces ( (7 4 0 3) (15 12 8 11) (9 13 14 10) (29 9 10 30) (25 29 30 26) (5 25 26 6) (1 5 6 2) (22 18 17 21) (21 22 23 20) (16 19 18 17) ); } paroiChaude { type wall; faces ( (11 8 28 31) (31 28 24 27) (27 24 4 7) (20 23 19 16) ); } frontAndBack { type empty; faces ( // (6 7 3 2) (35 7 3 42) (34 35 42 43) (6 34 43 2) (19 27 7 35) (18 19 35 34) (26 18 34 6) (23 31 27 19) (30 22 18 26) (39 11 31 23) (38 39 23 22) (10 38 22 30) (14 15 11 10) // (4 5 1 0) (4 32 40 0) (32 33 41 40) (33 5 1 41) (24 16 32 4) (16 17 33 32) (17 25 5 33) (28 20 16 24) (21 29 25 17) (8 36 20 28) (36 37 21 20) (37 9 29 21) (12 13 9 8) ); } ); mergePatchPairs ( ); // ************************************************************************* // //(6 5 33 34) here and bellow planes corresponding //(34 33 32 35) to defaultFace //(35 32 4 7) //(10 9 37 38) //(38 37 36 39) //(39 36 8 11) //(9 8 11 10) //(5 4 7 6) Cheers, Antimony |
July 1, 2019, 07:14 |
Rep Power: 6 |
Hello. Thanks for your answer and your mesh edit. I've perfecly understood what you meant. It works.
Display Modes | |
