July 8, 2019, 04:40 |
Non Orthogonal Faces in checkMesh
Raza Javed
Rep Power: 7 |
Hello Everyone,
My geometry consists of a box and a rectangular pipe inside. I want to have smaller number of cells in pipe region as compared to box region. I used submesh for this in salome, but when I import the UNV file of this mesh into Openfoam, and RUN the checkMesh, it gives the non-orthogonal faces in my mesh. I read that If we use noOrthoCorrectors in fvSolutions, then we will not have any problem in simulation. but I don't know, how to use that. for example, If I have 2000 non-orthogonal faces, then how many nonOrthoCorrectors I should use in fvSolutions? And in which fvSolution I will put this? because I have fvSolution file in both pipe and box region. I shall be thankful if someone can help me in this. Thank you |
meshing, openfoam, salome |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
