[snappyHexMesh] refinement by region
Old   July 3, 2019, 12:48
Default refinement by region
shima
shimakasaei is on a distinguished road
Hi all,
I am using snappyhexmesh for my model. I am modeling 3blocks and I want to refine mesh area around the blocks. When I use refinement box with searchable type, and define refinement box -with the area that I want to be refined- in refinement region, it does create mesh but not refine them as I expect.
Can anyone please let me know where the problem is?
here is snappyhexmeshdict:
/*--------------------------------*- C++-*----------------------------------*\\
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers false;
geometry
A3b1.stl
type triSurfaceMesh;
name A3b1;
A3b2.stl
name A3b2;
A3b3.stl
name A3b3;
refinementBox //USER DEFINED REGION NAME
type searchableBox; //REGION DEFINED BY BOUNDING BOX
min (5.6 0 0); //parameters
max ( 7.5 1.5 0.5 );
castellatedMeshControls
maxLocalCells 10000000;
maxGlobalCells 10000000;
minRefinementCells 10;
maxLoadUnbalance 0.10;
nCellsBetweenLevels 3;
features
refinementSurfaces
A3b1
level (0 0);
A3b2
level (0 0);
A3b3
level (0 0);
resolveFeatureAngle 65;
refinementRegions
refinementBox
mode inside;
levels ((0.001 3));
locationInMesh (0.005 0.005 0.005);
allowFreeStandingZoneFaces true;
snapControls
nSmoothPatch 3;
tolerance 4.0;
nSolveIter 30;
nRelaxIter 5;
nFeatureSnapIter 5;
addLayersControls
relativeSizes true;
layers
expansionRatio 1.0;
finalLayerThickness 0.3;
minThickness 0.1;
nGrow 1;
featureAngle 30;
nRelaxIter 3;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedianAxisAngle 130;
nBufferCellsNoExtrude 0;
nLayerIter 50;
nRelaxedIter 20;
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality -1E30;
minArea -1;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.02;
minVolRatio 0.01;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
//relaxed
// maxNonOrtho 80;
debug 0;
mergeTolerance 1e-6;
Thanks,
Shima
shimakasaei is offline   Reply With Quote
Old   July 5, 2019, 07:32
Thomas Sprich
Swift is on a distinguished road
Hi Shima,
Try making this change under refinementRegions:
refinementRegions
refinementBox
mode inside;
levels ((1E15 3));
Does this work
Thomas
Swift is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 3 March 12, 2020 18:50
[snappyHexMesh] Multi Region Mesh of a car filter Zephiro88 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2019 20:34
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 11:11
[snappyHexMesh] Refinement region - distance not working Rasmusiwersen OpenFOAM Meshing & Mesh Conversion 1 May 3, 2019 07:37
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 16:53
