[Salome] Non-orthogonal mesh
Old   July 8, 2019, 10:48
Default Non-orthogonal mesh
Priyanka P
priyankap is on a distinguished road
Originally Posted by Tobi View Post
the generation of 3D meshes within the Salome toolbox takes long, that is a fact. However, non-orthogonality in the mesh is not a big deal for OpenFOAM. You have to choose the appropriate numerical schemes for that. E.g. for the laplacian scheme, you can use a limited one.
Good luck, by the way - your reply is off-topic as this thread is about surface triangulation for snappyHexMesh
Thank you for your reply.
I am starting a new thread.
So, if I want to handle this non-orthogonality in heatTransfer problem, where I am using chtMultiRegionSimpleFoam, which laplacian scheme should I exactly use?
laplacianSchemes
    default         none;
    laplacian(alpha,h)  Gauss linear corrected;
Should I change laplacian(alpha,h)? Which scheme should I exactly use? I am sorry if iI am asking stupid questions Because I am not very familiar with numerical schemes.
Also, should I change this laplacian scheme in all the regions of my case or just the fluid region?
Thanks.
priyankap is offline   Reply With Quote
[snappyHexMesh] Snapping problem, non orthogonal faces Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 April 17, 2015 02:56
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
