[CAD formats] How can i export CAD file and make a mesh? |
July 20, 2019, 11:33 |
Leegunho
Rep Power: 6 |
Hello Foamers. I'm university student from Korea
I'm designing a Supersonic Wind tunnel which will be used in my professor's lab. I've already made a CAD modeling for supersonic nozzle for Mach number 3, 4.5, 6 with CREO I want to simulate these nozzles with OpenFoam to see whether the outlet Mach number matches the design test section Mach number for the boundary condition of inlet pressure, outlet pressure. To see the boundary layer viscous effect and make a correction for the nozzle, i want to export my CAD file and make a mesh with it. I'm totally new in OpenFoam, so could you recommend me an advice or tutorials for it? I'll attach jpg file of my CAD design for nozzle. (Cross section view. left side is inlet and right side is outlet) Sorry for my bad English :< |
July 21, 2019, 02:19 |
Rep Power: 6 |
Hello Kim,
are you also completely new in CFD ? I would recommend to begin with the basic and not with subsonic and supersonic flow. Start with incom. Flows and Tutorials. Try to understand what is important on a mesh. https://www.openfoam.com/documentation/tutorial-guide/ . Then go back to your original problem. Best Regards |
July 28, 2019, 10:47 |
Rep Power: 7 |
The CAD software you use, needs to provide the possibility to export the nozzle as a mesh. I usually use the *.obj file format. *.stl should also work.
Sometime I use the free software MeshLab to turn, scale of move the resulting mesh output from the CAD software. You can open such an *obj or *.stl file in paraView to check how it fits into a domain you created beforehand e.g. by the blockMesh utility. Then you need to store the mesh in the constant/triSurface folder and use snappyHexMesh. This requieres quite some time to have snappyHeymesh do what you wnat it to do, but it is worth it. Best, K. |
July 28, 2019, 14:32 |
Leegunho
Rep Power: 6 |
THANKS
I learned how to mesh the geometry designed from CREO or other CAD. Now i'm stuck with some other problems like Meshing or Initialization. I'm going to learn step by step. Again thanks for your reply. |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
