December 3, 2012, 01:20 |
Skewness Problems
Lucas
Rep Power: 13 |
Hi, I'm a relatively new OF user - this issue probably has been addressed a number of times.
For a simple internal flow problem from one opening through to another, I am unable to begin solving using SimpleFoam. Blockmeshdict and the checkMesh are shown below. I just want to know how one would go about fixing the errors shown in the mesh check in order to run the solver? If you run blockMesh and view the wireframe in paraview, you'll see that the geometry is split up into 3 quadrilaterals - two rectangles and a trapezium. I assume the trapezium shaped section is the cause of the problem due to the largely skewed cells. Can anyone come up with a quick solution to fix this? Thanks! Lucas /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) //0 (-5 -5 0) //1 (5 -15 0) //2 (10 -10 0) //3 (0 0 4) //4 (-5 -5 4) //5 (5 -15 4) //6 (10 -10 4) //7 (0 0 0) //8 (10 -10 0) //9 (20 -10 0) //10 (20 0 0) //11 (0 0 4) //12 (10 -10 4) //13 (20 -10 4) //14 (20 0 4) //15 (0 0 0) //16 (20 0 0) //17 (20 5 0) //18 (0 5 0) //19 (0 0 4) //20 (20 0 4) //21 (20 5 4) //22 (0 5 4) //23 (20 -5 0) //24 (20 -3 0) //25 (20 -5 3) //26 (20 -3 3) //27 (20 -5 0) //28 (20 -3 0) //29 (20 -5 3) //30 (20 -3 3) //31 (17 -10 0) //32 (18.5 -10 0) //33 (17 -10 3) //34 (18.5 -10 3) //35 (17 -10 0) //36 (18.5 -10 0) //37 (17 -10 3) //38 (18.5 -10 3) //39 (10 0 0) //40 (10 0 3) //41 (10 0 0) //42 (10 0 3) //43 ); blocks ( hex (0 1 2 3 4 5 6 7) (50 100 40) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (100 200 40) simpleGrading (1 1 1) hex (16 17 18 19 20 21 22 23) (200 50 40) simpleGrading (1 1 1) hex (32 33 37 36 34 35 39 38) (15 1 30) simpleGrading (1 1 1) hex (24 25 29 28 26 27 31 30) (20 1 30) simpleGrading (1 1 1) ); edges ( ); patches ( wall upper ( (0 1 2 3) (8 9 10 11) (16 17 18 19) ) wall lower ( (4 7 6 5) (12 15 14 13) (20 23 22 21) ) wall sides ( (1 5 6 2) (3 2 6 7) (1 0 4 5) (11 10 14 15) (16 19 23 20) (19 18 22 23) ) patch door1 ( (32 33 35 34) (36 37 39 38) ) patch inlet ( (10 9 13 14) (24 25 27 26) (28 29 31 30) ) patch outlet ( (18 17 21 22) ) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 1465933 faces: 4267115 internal faces: 4139005 cells: 1401050 boundary patches: 6 point zones: 4 face zones: 12 cell zones: 0 Overall number of cells of each type: hexahedra: 1400870 prisms: 164 wedges: 8 pyramids: 0 tet wedges: 8 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 5 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology upper 35000 35703 ok (non-closed singly connected) lower 35000 35703 ok (non-closed singly connected) sides 22000 22673 ok (non-closed singly connected) inlet 8000 8241 ok (non-closed singly connected) outlet 2000 2091 ok (non-closed singly connected) defaultFaces 26110 26833 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-5 -15 0) (20 5 4) Mesh (non-empty, non-wedge) directions (0 0 1) Mesh (non-empty) directions (0 0 1) ***Number of edges not aligned with or perpendicular to non-empty directions: 1236150 <<Writing 1039391 points on non-aligned edges to set nonAlignedEdges Boundary openness (1.68712e-17 -1.16793e-15 1.93548e-14) OK. Max cell openness = 2.44327e-16 OK. Max aspect ratio = 1 OK. ***Zero or negative face area detected. Minimum area: 0 <<Writing 2015 zero area faces to set zeroAreaFaces Min volume = 1.33333e-300. Max volume = 0.0444444. Total volume = 1432.33. Cell volumes OK. Mesh non-orthogonality Max: 90 average: 17.4404 ***Number of non-orthogonality errors: 2005. <<Writing 2005 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 1042 faces are incorrectly oriented. <<Writing 1042 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 57.5098, 1068 highly skew faces detected which may impair the quality of the results <<Writing 1068 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 5 mesh checks. End Last edited by lucasw7; December 3, 2012 at 23:02. |
December 3, 2012, 04:11 |
Rep Power: 15 |
Sorry I dont have the exact syntax to hand, but what you need to do is use the FoamToVTK function to get a VTK file of the skewed faces.
Then you can open the VTK file and the mesh in Paraview. From there you should be able to identify where the skewed surfaces are and do something with the geometry so that the faces don't get skewed when being meshed. |
December 3, 2012, 23:05 |
#3 | |
Lucas
Rep Power: 13 |
December 4, 2012, 02:58 |
Rep Power: 15 |
The point to my original post was, you need to modify your mesh so that the skew faces do not exist in the first place. Then you should be able to get the solver to run. Without knowing where the skewness exists in your geometry you are going to be hard pushed to know how to modify it to get rid of it. Hence this is why I gave the advice so you should be able to visualize the location of the skewed faces. |
December 21, 2016, 19:58 |
Ken
Rep Power: 10 |
what's the exact syntax you used for the skewfaces? i tried faceset and cellset but they dont worl.
December 22, 2016, 01:20 |
Rep Power: 15 |
I believe it should be: foamToVTK -faceSet skewFaces -ascii The ASCII option may not be needed, but I prefer to put it as long as the file size isn't huge. Cheers, Antimony |
July 11, 2019, 00:52 |
Thanks
Milan
Rep Power: 9 |
check mesh, skewness |
[ANSYS Meshing] Fluent Meshing results in very high skewness | FFD | ANSYS Meshing & Geometry | 10 | August 31, 2017 11:09 |
URANS 2D Square Cylinder Problems | and_user | OpenFOAM Running, Solving & CFD | 5 | May 24, 2017 21:01 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
[GAMBIT] Meshing problems | iHal | ANSYS Meshing & Geometry | 6 | February 25, 2010 08:21 |
SimpleFoam problems with converging maybe skewness | hoochie | OpenFOAM Running, Solving & CFD | 4 | May 14, 2007 07:23 |
