ideasUnvToFoam fails upon creating Grouponvolume
I am using Salome 8.3 to make a mesh of a butterfly valve in order to simulate closing of valve and pressure rise in the pipe before the valve. I can make the mesh successfully but when i create "Group on volume" to assign cellzone in OpenFoam extend 4.0, the command ideasUnvToFoam fails by giving error: Create time Processing tag:164 Starting reading units at line 3. l:1 units:" SI: Meter (newton)" unitType:2 Unit factors: Length scale : 1 Force scale : 1 Temperature scale : 1 Temperature offset : 273.15 Processing tag:2420 Skipping tag 2420 on line 9 Skipping section at line 9. Processing tag:2411 Starting reading points at line 20. Read 66508 points. Processing tag:2412 Starting reading cells at line 133039. First occurrence of element type 11 for cell 1 at line 133040 First occurrence of element type 41 for cell 531 at line 135068 First occurrence of element type 111 for cell 106941 at line 347596 Read 103353 cells and 106264 boundary faces. Processing tag:2467 Starting reading patches at line 554304. For group 1 named Outer_Wall trying to read 91776 patch face indices. For group 2 named Inlet trying to read 1507 patch face indices. For group 3 named Outlet trying to read 1507 patch face indices. For group 4 named GGI trying to read 7528 patch face indices. For group 5 named Disc trying to read 3463 patch face indices. For group 6 named Rotary trying to read 103353 patch face indices. Sorting boundary faces according to group (patch) --> FOAM FATAL ERROR: 166414 not found in table. Valid entries: 106264 ( .... 06931 106932 106933 106934 106935 106936 106937 106938 106939 106940 ) From function HashTable<T, Key, Hash>::operator[](const Key&) in file /home/himanshu/foam/foam-extend-4.0/src/foam/lnInclude/HashTableI.H at line 117. FOAM exiting Can someone please help me ? |
