[snappyHexMesh] Parallel meshing - SnappyHexMesh |
July 23, 2019, 10:01 |
Akanksha Rawat
Rep Power: 12 |
I am facing a Problem while meshing mmy geometry in parallel mode. I am using Scotch method and at the Point of Removing mesh beyond Surface intersections it gives me error - [0] [1] [1] [1] --> FOAM FATAL ERROR: [1] Global -1 does not belong on any processor. Offsets:4(0 676 1721 1844) [1] [1] From function Foam::label Foam::globalIndex::whichProcID(Foam::label) const [1] in file /home/pawan/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/globalIndexI.H at line 230. [1] FOAM parallel run aborting [1] [0] [0] --> FOAM FATAL ERROR: [0] Global -1 does not belong on any processor. Offsets:4(0 676 1721 1844) [0] [0] From function Foam::label Foam::globalIndex::whichProcID(Foam::label) const [0] in file /home/pawan/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/globalIndexI.H at line 230. [0] FOAM parallel run aborting [0] [0] #0 Foam::error:rintStack(Foam::Ostream&)[1] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [1] #1 Foam::error::abort() at ??:? [0] #1 Foam::error::abort() at ??:? [0] #2 Foam::regionSplit::reduceRegions(int, Foam::List<bool> const&, Foam::List<int>&) const at ??:? [1] #2 Foam::regionSplit::reduceRegions(int, Foam::List<bool> const&, Foam::List<int>&) const at ??:? [0] #3 Foam::regionSplit::calcRegionSplit(bool, Foam::List<bool> const&, Foam::List<Foam::Pair<int> > const&, Foam::List<int>&) const at ??:? [1] #3 Foam::regionSplit::calcRegionSplit(bool, Foam::List<bool> const&, Foam::List<Foam::Pair<int> > const&, Foam::List<int>&) const at ??:? [0] #4 Foam::regionSplit::regionSplit(Foam:olyMesh const&, Foam::List<bool> const&, bool) at ??:? [1] #4 Foam::regionSplit::regionSplit(Foam:olyMesh const&, Foam::List<bool> const&, bool) at ??:? [0] #5 Foam::meshRefinement::findCellZoneInsideWalk(Foam: :Field<Foam::Vector<double> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int>&) const at ??:? [1] #5 Foam::meshRefinement::findCellZoneInsideWalk(Foam: :Field<Foam::Vector<double> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int>&) const at ??:? [0] #6 Foam::meshRefinement::zonify(bool, int, int, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&, Foam::bitSet&) const at ??:? [1] #6 Foam::meshRefinement::zonify(bool, int, int, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&, Foam::bitSet&) const at ??:? [0] #7 Foam::meshRefinement::getBafflePatches(int, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int>&, Foam::List<int>&) const at ??:? [1] #7 Foam::meshRefinement::getBafflePatches(int, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int>&, Foam::List<int>&) const at ??:? [0] #8 Foam::meshRefinement::removeLimitShells(int, int, Foam::List<int> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&) at ??:? [1] #8 Foam::meshRefinement::removeLimitShells(int, int, Foam::List<int> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&) at ??:? [0] #9 Foam::snappyRefineDriver::removeInsideCells(Foam:: refinementParameters const&, int) at ??:? [1] #9 Foam::snappyRefineDriver::removeInsideCells(Foam:: refinementParameters const&, int) at ??:? [0] #10 Foam::snappyRefineDriver::doRefine(Foam::dictionar y const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, bool, Foam::dictionary const&) at ??:? [1] #10 Foam::snappyRefineDriver::doRefine(Foam::dictionar y const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, bool, Foam::dictionary const&) at ??:? [0] #11 at ??:? [1] #11 ?? at ??:? [0] #12 __libc_start_main at ??:? [1] #12 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 [0] #13 in /lib/x86_64-linux-gnu/libc.so.6 [1] #13 ?? at ??:? Anybody knows what is or could be wrong ? Thanks |
July 31, 2019, 03:06 |
Carlo_P
Rep Power: 7 |
Hey,
can you post here the snappyHexMeshDict? Secondarly, can you move a little your point? Maybe you are unlikly and the point is on a cell face. This creates problems. Cheers |
November 19, 2019, 08:45 |
David GISEN
I have the same problem using v1812 in parallel. Shifting the locationInMesh did not work. In serial, the mesh is created. The last correct output is
Setting cellZones according to locationsInMesh: Location : (10.156 -10.067 83.067) cellZone : none [5] [5] [5] --> FOAM FATAL ERROR: [5] Global -1 does not belong on any processor. Offsets: Any ideas? |
March 3, 2022, 07:52 |
Same issue here
Rasmus Iwersen
Rep Power: 8 |
Anyone with how to resolve this problem? I have the same issue..
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials | denbjornen | OpenFOAM Meshing & Mesh Conversion | 1 | May 25, 2020 11:14 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
[snappyHexMesh] snappyHexMesh Parallel bad size error | andrewpomeroy | OpenFOAM Meshing & Mesh Conversion | 2 | April 2, 2018 01:08 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 11:55 |
[snappyHexMesh] snappyHexMesh in parallel with cyclics | tonyuprm | OpenFOAM Meshing & Mesh Conversion | 1 | June 29, 2011 10:43 |
