[Technical] CCMIO Library 32-bit label maximum |
August 15, 2019, 18:48 |
Rep Power: 10 |
Hello everyone,
I am working with converting larger Star-CCM+ meshes into OpenFOAM. I'm currently exceeding the 32-bit label maximum, as the converter is written using doubles and int_32t variable type. Has anyone implemented a 64-bit label version of this utility? from the wmake/script/have_ccmio file: Code:
# ---------------------------------- # The libccmio uses int32_t. # The OpenFOAM adapter thus requires additional work for 64-bit labels. # The OpenFOAM adapter was originally only designed for 'double' local good if [ "$WM_LABEL_SIZE" = 32 ] then if [ "$WM_PRECISION_OPTION" = DP ] then good=true else [ -n "$warn" ] && echo "$warn (double precision only)" no_ccmio return 1 fi else [ -n "$warn" ] && echo "$warn (32-bit labels only)" no_ccmio return 1 fi # ---------------------------------- |
Saved in Workbench 32 bit, open in Workbench 64 bit. | Black Ni | ANSYS | 2 | July 28, 2011 09:32 |
Issue with running in parallel on multiple nodes | daveatstyacht | OpenFOAM | 7 | August 31, 2010 17:16 |
64 Bit software or 64 bit compatibility? | EphemeralMemory | ANSYS | 1 | August 31, 2010 05:29 |
UDF problem/32 bit vs. 64 bit | RE13 | FLUENT | 2 | February 25, 2008 11:31 |
fluent 32 bit maximum RAM | Mike | FLUENT | 2 | August 19, 2006 09:45 |
