[mesh manipulation] Found loop on cell that resulted in an unexpected bad cut. |
L S
Rep Power: 8 ![]() |
Hello everyone,
I have been trying to mesh a geometry for the problem , "Cross flow over cylinder" in 2D. After meshing i used refineMeshDict facility to refine more around cylinder. But, I have been getting bad mesh at the intersections where two neighbouring blocks meet. Following is the warning it is showing: Code:
FOAM Warning : From function void Foam::cellCuts::setFromCellCutter(const Foam::cellLooper&, const Foam::List<Foam::refineCell>&) in file meshCut/cellCuts/cellCuts.C at line 2393 Found loop on cell 68422 that resulted in an unexpected bad cut. Suggestions: - Turn on the debug switch for 'cellCuts' to get geometry files that identify this cell. - Also keep in mind to check the defined reference directions, as these are most likely the origin of the problem. Code:
set c0; coordinateSystem global; globalCoeffs { tan1 (1 1 0); tan2 (-1 1 0); } directions ( tan1 tan2 ); useHexTopology yes; geometricCut no; writeMesh no; Code:
actions ( { name c0; type cellSet; action new; source cylinderAnnulusToCell; sourceInfo { p1 (0 0 -0.05); outerRadius 0.015; p2 (0 0 0.05); innerRadius 0.001; } } ); Code:
actions ( { name c0; type cellSet; action new; source cylinderAnnulusToCell; sourceInfo { p1 (0 0 -0.05); outerRadius 0.011; p2 (0 0 0.05); innerRadius 0.005; } } ); The bad cut cells can be seen in following pics. The case file to reproduce the errors is also attached in google drive: https://drive.google.com/file/d/1gUC...ew?usp=sharing |
meshing 2d, openfoam, refinmeshdict, toposetdict |
Display Modes | |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
