[Other] dynamicRefineFvMesh does not unrefine the mesh |
javad haqqani
Rep Power: 9 ![]() |
Hi. I'm new to adaptive mesh refinement (AMR) and using OpenFOAM-3.0 in windows. Everything works fine except that the mesh does not get unrefined when the refinement situation is lifted. My dynamicMeshDict is as follows
dynamicRefineFvMeshCoeffs { refineInterval 1; field Cf;//concentration of a reactive species lowerRefineLevel 10; upperRefineLevel 100;// Cf varies between 0 and 165 unrefineLevel 2; nBufferLayers 0; maxRefinement 1; maxCells 40000; correctFluxes ( (phi none) ); dumpLevel true; } after a while in simulation, Cf reaches 165 (nearly homogeneous in the whole domain), but the mesh does not get unrefined |
javad haqqani
Found out that unrefinement happens when the value is lower than unrefine level not higher
adaptive mesh refinement |
Display Modes | |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 09:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
