[mesh manipulation] falling object simulation with OpenFoam |
September 18, 2019, 16:48 |
Rep Power: 11 |
Hello foamers.
This is my first entry at this forum. Sorry for any inconvenience. I need to simulate a free falling object in a medium, like a rock in a water I could not find any dynamic mesh solver for this particular problem. While the object is moving to bottom, it cause a shrinkage on the meshes under it and the simulation crashes eventually. I used sixDoFRigidBodyMotion. It can simulate the coupled motion of the object but does not remesh the domain or change the topology. Which dynamic mesh solvers or which meshing strategy should I use? I would be very happy If you can share your comments with me. |
September 19, 2019, 05:17 |
Yann
Rep Power: 26 |
Check the sphereDrop tutorial, it uses layer addition/removal technique with a sixDoFRigidBodyDisplacement boundary condition to simulate a falling sphere. Or as CFD_10 suggested, go for overset. Cheers, Yann |
September 19, 2019, 11:30 |
Rep Power: 11 |
Many thanks. I will look at OpenFoam ESI.
September 26, 2019, 00:18 |
Ted Spencer
Many thanks!
the impossible quiz |
dynamicmeshdict.sixdof, openfoam |
Solid object falling in water tank simulation | cassini83 | CFX | 3 | August 9, 2021 17:05 |
Coded function object in openfoam v5 | kit607 | OpenFOAM Post-Processing | 3 | September 29, 2020 15:43 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
OpenFoam Airfoil simulation - replacing Fluent with OpenFOAM | shereez234 | OpenFOAM Running, Solving & CFD | 1 | November 3, 2015 03:54 |
Is OpenFOAM capable to simulate a floating object with variable density? | Idosar | OpenFOAM | 0 | September 29, 2015 16:13 |
