[mesh manipulation] extrudeMesh creates intersecting regions |
May 20, 2016, 15:15 |
Rep Power: 11 |
I've used an extrudeMesh to create a solid domain for a FSI simulation.
Firstly, I've created a mesh for a fluid domain, then i've extruded a new mesh from a wall patch. The problem is that in the one region the original surfaces were very close to each other, so after the extrusion they are intersecting. You can see in attached images the general view of a model and a scaled region with intersection. Is there any way to remove this intersection and to remesh this region ? |
October 3, 2019, 13:35 |
alberto
Rep Power: 10 |
Im trying to do FSI with aneurysm, did you have succed? Im stuck with the solid mesh |
[Gmsh] gmshToFoam - Hybrid mesh conversion creates 2 regions | bhanu2204 | OpenFOAM Meshing & Mesh Conversion | 5 | February 18, 2018 07:04 |
[snappyHexMesh] MultiRegions: Snappy creates extra domains between Regions | Cartuns11 | OpenFOAM Meshing & Mesh Conversion | 3 | January 22, 2018 08:39 |
[snappyHexMesh] Multi region meshing with SHM creates extra regions | Dav3dum | OpenFOAM Meshing & Mesh Conversion | 0 | August 8, 2016 08:54 |
Determining the calculation sequence of the regions in multe regions calculation | peterhess | OpenFOAM Running, Solving & CFD | 4 | March 9, 2016 03:07 |
chtMultiRegionFoam different properties in (fluid) region(s) | volker1 | OpenFOAM Pre-Processing | 3 | February 4, 2015 06:46 |
