October 4, 2019, 05:16 |
renumberMesh
Pierre HORGUE
Rep Power: 16 |
Hi all,
I have a question about the renumberMesh utility since it may perform different renumbering but I can't find the origin. I created a volScalarField called meshid whose internalfield value is the cellID: Code:
internalField nonuniform List<scalar> 40483 ( 0 1 2 ... 40480 40481 40482 ); Code:
renumberMesh -overwrite Looking at the compiler options, I found that all OF versions are compiled with options Code:
linux64GccDPInt32Opt Thanks, Pierre |
October 9, 2019, 05:22 |
Pierre HORGUE
Rep Power: 16 |
Hi all,
I found the explanation. There are some issues in openfoam-version 7 of July 2019 which has been corrected (patched) in th version of September 2019. The pre-compiled packages are correctly updated but the source available on the website www.openfoam.org are from July 2019 and not updated. This should be updated on the website to avoid similar issues for of-user who wants to compile openfoam on their computers. Pierre |
[mesh manipulation] renumberMesh causes solver divergence | spaceprop | OpenFOAM Meshing & Mesh Conversion | 8 | November 22, 2021 17:18 |
[mesh manipulation] Some questions on blockMesh, decomposePar and renumberMesh | Leech | OpenFOAM Meshing & Mesh Conversion | 19 | April 5, 2019 19:21 |
[mesh manipulation] decomposePar Method affects executability of renumberMesh | Vyssion | OpenFOAM Meshing & Mesh Conversion | 0 | November 3, 2016 07:57 |
renumberMesh problems | Jonathan | OpenFOAM Pre-Processing | 1 | May 10, 2016 16:38 |
RenumberMesh causing divergence | altair279 | OpenFOAM Running, Solving & CFD | 0 | April 1, 2015 18:33 |
