A patch with two types
I am referring to the boundary file residing inside folder constant/polyMesh.
Perhaps these are stupid questions. 1) Can a type be both wall and cyclic ? I am thinking of the periodic set-up of blades in a compressor. 2) I have a patch of type wall since I will solve Navier Stokes equations near the interface between air and a solid. However, this interface also separates two different meshes and the same patch also needs to be of type mappedPatch because I use swak4Foam's groovyBC for an electric field boundary condition. Unfortunately, OF complains that the patch cannot be of both types.What can be done ? Have a great day, Marc |
OK, fine. If nobody knows, I'll stick with openFoam's
patchToPatchInterpolation.faceInterpolate(othersid epatch.patchInternalField()); use the above for your patch and in a file variableValueYourFieldVarFvPatchScalarField.C the following excerpt: void variableValueYourFieldVarFvPatchScalarField::updat eCoeffs() { if (updated()) { return; } operator==(*this); fixedValueFvPatchScalarField::updateCoeffs(); } which will be called if in dictionary 0/YourFieldVar, your patch has type variableValueYourFieldVar This way, I can keep type wall for the your patch in the boundary file. |
