Meshing Error Please Help!!!
I am having trouble with matching faces between blocks.
The error I receive is: Inconsistent number of faces between block pair 0 and 1 I have spent many hours trying to fix this problem and so am posting as a last resort. Any help would be greatly appreciated! Kind regards Ps. my code is below: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 0.01; vertices ( (0 2 2) (0 2 -2) (0 -2 -2) (0 -2 2) (0 6.243 6.243) (0 6.243 -6.243) (0 -6.243 -6.243) (0 -6.243 6.243) (0 7.657 7.657) (0 7.657 -7.657) (0 -7.657 -7.657) (0 -7.657 7.657) (100 2 2) (100 2 -2) (100 -2 -2) (100 -2 2) (100 6.243 6.243) (100 6.243 -6.243) (100 -6.243 -6.243) (100 -6.243 6.243) (100 7.657 7.657) (100 7.657 -7.657) (100 -7.657 -7.657) (100 -7.657 7.657) ); blocks ( hex (0 3 2 1 12 15 14 13) (100 10 10) simpleGrading (1 1 1) hex (0 1 5 4 12 13 17 16) (100 10 10) simpleGrading (1 1 1) hex (1 2 6 5 13 14 18 17) (100 10 10) simpleGrading (1 1 1) hex (2 3 7 6 14 15 19 18) (100 10 10) simpleGrading (1 1 1) hex (3 0 4 7 15 12 16 19) (100 10 10) simpleGrading (1 1 1) hex (4 5 9 8 16 17 21 20) (100 10 10) simpleGrading (1 1 1) hex (5 6 10 9 17 18 22 21) (100 10 10) simpleGrading (1 1 1) hex (6 7 11 10 18 19 23 22) (100 10 10) simpleGrading (1 1 1) hex (7 4 8 11 19 16 20 23) (100 10 10) simpleGrading (1 1 1) ); edges ( arc 7 4 (0 0 8) arc 11 8 (0 0 10) arc 4 5 (0 8 0) arc 8 9 (0 10 0) arc 5 6 (0 0 -8) arc 9 10 (0 0 -10) arc 6 7 (0 -8 0) arc 10 11 (0 -10 0) arc 19 16 (100 0 8) arc 23 20 (100 0 10) arc 16 17 (100 8 0) arc 20 21 (100 10 0) arc 17 18 (100 0 -8) arc 21 22 (100 0 -10) arc 18 19 (100 -8 0) arc 22 23 (100 -10 0) ); boundary ( inlet { type patch; faces ( (0 1 2 3) (0 4 5 1) (4 8 9 5) (1 5 6 2) (5 9 10 6) (2 6 7 3) (6 10 11 7) (0 3 7 4) (7 11 8 4) ); } outlet { type patch; faces ( (12 15 14 13) (12 13 17 16) (16 17 21 20) (13 14 18 17) (17 18 22 21) (14 15 19 18) (18 19 23 22) (12 16 19 15) (16 20 23 19) ); } Walls { type wall; faces ( (8 11 23 20) (9 8 20 21) (21 22 10 9) (10 22 23 11) ); } ); ----------------------------- Running blockMesh ------------------------------ Create time Creating block mesh from "system/blockMeshDict" Creating block edges No non-planar block faces defined Creating topology blocks Creating topology patches Creating block mesh topology Check topology Basic statistics Number of internal faces : 16 Number of boundary faces : 22 Number of defined boundary faces : 22 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list --> FOAM FATAL ERROR: Inconsistent number of faces between block pair 0 and 1 From function void Foam::blockMesh::calcMergeInfo() in file blockMesh/blockMeshMerge.C at line 223. FOAM exiting ---------------------------------- |
Hello Ollie, I don't really know what's wrong with your blockMeshDict. I simply gave up to use it and switched over to Salome, where the blockMesh for simple geometries can be meshed very easily. Just this morning I released my new video about this procedure, maybe interesting for you:
https://www.youtube.com/watch?v=CoIDdIAUnzE best, Damian |
