November 20, 2019, 07:23 |
Creating an axisymmetric mesh
Andrew Lindsay
Rep Power: 17 |
OK, So I have managed to create a mesh with blockmeshDict, and everything runs without any issues when I convert it using blockMesh.
But now that I have added in the wedge commands, I am getting a number of errors as follows (though I'll only show the first error here). Creating block mesh topology --> FOAM Warning : From function virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBu ffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72 Wedge patch 'wedgeleft' is not planar. At local face at (0 6.66032 0) the normal (-1 0 0) differs from the average normal (-0.944803 0.0960173 -5.36283e-18) by 0.0122661 Either correct the patch or split it into planar parts My blockmeshDict file is attached as a text file Any suggestions as to how to correct these errors would be greatly appreciated. |
November 20, 2019, 07:52 |
Andrew Lindsay
Rep Power: 17 |
Just before anyone suggests. Yes, I have tried changing the wedges to patches, and it converts/compiles perfectly in blockMesh, without any warnings or errors.
I have tried increasing the writeprecision from 6 to 20, and I have also changed the write format to binary, all without any success. Regards Andrew |
November 20, 2019, 21:36 |
Andrew Lindsay
Rep Power: 17 |
OK,
So I am finding out a lot of things through trial and error (lots of trial, and humongous amounts of error). But, success!!! I have found that blockmesh can be very forgiving for some things, and quite pedantic on others. I had assumed, incorrectly, that blockmesh would just lump all wedge blocks together and 'sort it out in the wash' so to speak. But, long story short, I had not set up separate wedge regions for the front and back, I had simply called them the same thing. As soon as I created a front wedge group and a back wedge group, everything worked perfectly. I am not the proud owner of a fully compiled mesh, I will start down the track now of setting up the cht sections of the model. Here is my now working blockmesh file. When I tidy it up, I will post my excel workbook that does all the calculations in case anyone would be interested. |
Display Modes | |
[ANSYS Meshing] "Wedge" mesh - axisymmetric problem | sultzan | ANSYS Meshing & Geometry | 12 | October 11, 2017 16:04 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
2D axisymmetric Mesh problem in OpenFoam | Javed | OpenFOAM | 3 | September 22, 2011 03:23 |
[Other] Problem when trying to generate a new mesh | gaottino | OpenFOAM Meshing & Mesh Conversion | 0 | June 30, 2006 08:51 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
