Error: face does not have neighbour cell face
Hello, I have written the blockMeshDict file as follows
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) //0 (1.25 0 0) //1 (1.25 0.8 0) //2 (0 0.8 0) //3 (0 0 0.2) //4 (1.25 0 0.2) //5 (1.25 0.8 0.2) //6 (0 0.8 0.2) //7 (1.43 0.0405 0) //8 (1.43 0.0405 0.2) //9 (1.637 0.144 0) //10 (1.65 0.15 0) //11 (1.551 0.352 0) //12 (1.541 0.347 0) //13 (1.637 0.144 0.2) //14 (1.65 0.15 0.2) //15 (1.551 0.352 0.2) //16 (1.541 0.347 0.2) //17 (1.532 0.365 0) //18 (1.56 0.347 0) //19 (1.56 0.8 0) //20 (1.322 0.8 0) //21 (1.532 0.365 0.2) //22 (1.56 0.347 0.2) //23 (1.56 0.8 0.2) //24 (1.322 0.8 0.2) //25 (1.745 0 0) //26 (1.745 0.8 0) //27 (1.745 0 0.2) //28 (1.745 0.8 0.2) //29 (2.5 0 0) //30 (2.5 0.8 0) //31 (2.5 0 0.2) //32 (2.5 0.8 0.2) //33 (1.373 0.265 0) //34 (1.369 0.285 0) //35 (1.25 0.285 0) //36 (1.25 0.265 0) //37 (0 0.285 0) //38 (0 0.265 0) //39 (1.373 0.265 0.2) //40 (1.369 0.285 0.2) //41 (1.25 0.285 0.2) //42 (1.25 0.265 0.2) //43 (0 0.285 0.2) //44 (0 0.265 0.2) //45 ); blocks ( hex (0 1 37 39 4 5 43 45) (20 20 1) simpleGrading (1 1 1) hex (39 37 36 38 45 43 42 44) (20 20 1) simpleGrading (1 1 1) hex (38 36 2 3 44 42 6 7) (20 20 1) simpleGrading (1 1 1) hex (1 8 34 37 5 9 40 43) (20 20 1) simpleGrading (1 1 1) hex (37 34 35 36 43 40 41 42) (20 20 1) simpleGrading (1 1 1) hex (36 35 2 2 42 41 6 6) (20 20 1) simpleGrading (1 1 1) hex (8 10 13 34 9 14 17 40) (20 20 1) simpleGrading (1 1 1) hex (34 13 18 35 40 17 21 41) (20 20 1) simpleGrading (1 1 1) hex (35 18 21 2 41 22 25 6) (20 20 1) simpleGrading (1 1 1) hex (10 11 12 13 14 15 16 17) (20 20 1) simpleGrading (1 1 1) hex (18 19 20 21 22 23 24 25) (20 20 1) simpleGrading (1 1 1) hex (19 26 27 20 23 28 29 24) (20 20 1) simpleGrading (1 1 1) hex (26 30 31 27 28 32 33 29) (20 20 1) simpleGrading (1 1 1) ); edges ( arc 1 8 (1.34 0.0102 0) arc 5 9 (1.34 0.0102 0.2) ); boundary ( leftWall { type wall; faces ( (0 1 37 39) (39 37 36 38) (38 36 2 3) (1 8 34 37) (37 34 35 36) (36 35 2 2) (8 10 13 34) (34 13 18 35) (35 18 21 2) (10 11 12 13) (18 19 20 21) (19 26 27 20) (26 30 31 27) ); } rightWall { type wall; faces ( (4 5 43 45) (45 43 42 44) (44 42 6 7) (5 9 40 43) (43 40 41 42) (42 41 6 6) (9 14 17 40) (40 17 22 41) (41 22 25 6) (14 15 16 17) (22 23 24 25) (23 28 29 24) (28 32 33 29) ); } lowerWall { type wall; faces ( (0 1 5 4) (1 8 9 5) (8 10 14 9) (10 11 15 14) (11 12 16 15) (12 13 17 16) (18 13 17 22) (18 19 23 22) (19 26 28 23) (26 30 32 28) ); } endWall { type wall; faces ( (0 4 7 3) ); } frontWall { type wall; faces ( (30 32 33 31) ); } atmosphere { type patch; faces ( (3 31 33 7) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // However, I get the following problem even I have checked that there should be fine of the vertices ordering. I have followed all the same ordering. /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-ca808c8420bf Exec : blockMesh Date : Dec 01 2019 Time : 10:38:52 Host : "kelvin-VirtualBox" PID : 12546 I/O : uncollated Case : /home/kelvin/OpenFOAM/kelvin-7/run/damBreak nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/kelvin/OpenFOAM/kelvin-7/run/damBreak/system/blockMeshDict" Creating block edges No non-planar block faces defined Creating topology blocks Creating topology patches Creating block mesh topology --> FOAM FATAL ERROR: face 7 in patch 1 does not have neighbour cell face: 4(40 17 22 41) From function Foam::labelList Foam::polyMesh::facePatchFaceCells(const faceList&, const labelListList&, const faceListList&, Foam::label) const in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 118. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::polyMesh::facePatchFaceCells(Foam::List<Foam ::face> const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const at ??:? #3 Foam::polyMesh::setTopology(Foam::List<Foam::cellS hape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, int&, int&, Foam::List<Foam::cell>&) at ??:? #4 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<Foam::Vector<double> >&&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) at ??:? #5 Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) at ??:? #6 Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) at ??:? #7 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/blockMesh" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/blockMesh" Aborted (core dumped) Would all please help me to get rid of the problem? Many Thanks for all kindly help. |
