December 4, 2019, 12:57 |
concave cells/concaveFaces
shima
Rep Power: 8 |
Hi all,
I have a simulation model which has boxes inside a flume. All geometeries are simple without any curvature or slope. After running snappyHexMesh (I used it to generate boxes and refine mesh in area around blocks), I started the simulation and it was crashed showing an error that :No base point for face 11252089, 5(3950857 3977716 3977717 4849004 3950858), produces a decomposition that has a minimum volume greater than tolerance. When I run checkMesh -allGeometery, it shows me concaveCells and Faces. Here is what I have with checkMesh -allGeometery: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Enabling all geometry checks. Time = 0 Mesh stats points: 126245292 faces: 376149362 internal faces: 374320813 cells: 124953645 faces per cell: 6.005989 boundary patches: 9 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 124702557 prisms: 180 wedges: 0 pyramids: 0 tet wedges: 102 tetrahedra: 0 polyhedra: 250806 Breakdown of polyhedra by number of faces: faces number of cells 5 232 6 2644 8 65 9 246235 11 12 12 1512 15 106 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box inlet 11250 11476 ok (non-closed singly connected) (0 0 0) (0 1.5 0.75) outlet 11250 11476 ok (non-closed singly connected) (15 0 0) (15 1.5 0.75) leftwall 294564 297016 ok (non-closed singly connected) (0 1.5 0) (15 1.5 0.75) rightwall 294564 297016 ok (non-closed singly connected) (0 0 0) (15 0 0.75) bottom 736800 740222 ok (non-closed singly connected) (0 0 0) (15 1.5 0) top 223050 224851 ok (non-closed singly connected) (0 0 0.75) (15 1.5 0.75) A3b1 85832 86310 ok (non-closed singly connected) (6.59994 0.1241463 0) (6.850059 0.3758527 0.75) A3b2 85602 86097 ok (non-closed singly connected) (6.599942 0.6241819 0) (6.850127 0.875807 0.75) A3b3 85637 86124 ok (non-closed singly connected) (6.599926 1.124148 0) (6.850074 1.375607 0.75) Checking geometry... Overall domain bounding box (0 0 0) (15 1.5 0.75) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-6.720224e-17 -1.083957e-13 2.300914e-12) OK. Max cell openness = 2.821353e-16 OK. Max aspect ratio = 5.383686 OK. Minimum face area = 5.105227e-06. Maximum face area = 0.0001351346. Face area magnitudes OK. Min volume = 1.352747e-08. Max volume = 1.234041e-06. Total volume = 16.7344. Cell volumes OK. Mesh non-orthogonality Max: 53.93429 average: 1.296363 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.7117331 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 0.002001521 0.0136275 OK. *There are 461 faces with concave angles between consecutive edges. Max concave angle = 71.20371 degrees. <<Writing 461 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.8910414 average = 0.9999999 All face flatness OK. Cell determinant (wellposedness) : minimum: 0.1489069 average: 8.041237 Cell determinant check OK. ***Concave cells (using face planes) found, number of cells: 244507 <<Writing 244507 concave cells to set concaveCells Face interpolation weight : minimum: 0.106129 average: 0.4995235 Face interpolation weight check OK. Face volume ratio : minimum: 0.01914057 average: 0.9975404 Face volume ratio check OK. Failed 1 mesh checks. End I also attached picture of how concave cells look in paraview. I would appreciate if anyone can help me solve this!! Thanks, Shima |
December 4, 2019, 17:17 |
Herpes Free Engineer
Rep Power: 12 |
- concavity should be ok.
- could you please attach the full error log file of the simulation? - could you please do `checkMesh -allTopology -allGeometry`, and attach its log file?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
December 4, 2019, 17:22 |
shima
Rep Power: 8 |
Attached is the error of the simulation, I also attached the result of running checkMesh -allGeometery command. I should run checkMesh -allTopology as well to get the results.
December 4, 2019, 17:24 |
shima
Rep Power: 8 |
December 4, 2019, 17:30 |
Rep Power: 12 |
- the error log of the simulation is not full.
- can you decompose your case with fewer processors, and see if this helps. - your mesh quality seems to be OK to me.
December 5, 2019, 17:09 |
#6 | |
shima
Rep Power: 8 |
new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library [zagros-0-07:49305] *** Process received signal *** [zagros-0-07:49305] Signal: Aborted (6) [zagros-0-07:49305] Signal code: (-6) new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library [zagros-0-07:49310] *** Process received signal *** [zagros-0-07:49310] Signal: Aborted (6) [zagros-0-07:49310] Signal code: (-6) [zagros-0-07:49305] [ 0] [zagros-0-07:49310] /lib64/libc.so.6(+0x35250)[0x7f29a1703250] [zagros-0-07:49305] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7f29a17031d7] [zagros-0-07:49305] [ 2] /lib64/libc.so.6(abort+0x148)[0x7f29a17048c8] [zagros-0-07:49305] [ 3] [ 0] /lib64/libc.so.6(+0x35250)[0x7fb92d639250] [zagros-0-07:49310] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7fb92d6391d7] [zagros-0-07:49310] [ 2] /lib64/libc.so.6(abort+0x148)[0x7fb92d63a8c8] [zagros-0-07:49310] [ 3] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam8newErrorEv+0x54)[0x7fb92e6fa264] [zagros-0-07:49310] [ 4] /opt/ohpc/pub/compiler/gcc/5.4.0/lib64/libstdc++.so.6(_Znwm+0x2c)[0x7fb92df6b04c] [zagros-0-07:49310] [ 5] /opt/ohpc/pub/compiler/gcc/5.4.0/lib64/libstdc++.so.6(_Znam+0x9)[0x7fb92df6b0d9] [zagros-0-07:49310] [ 6] snappyHexMesh(_ZN4Foam4ListIiE7setSizeEi+0x2e)[0x423b4e] [zagros-0-07:49310] [ 7] new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library/home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam8newErrorEv+0x54)[0x7f29a27c4264] [zagros-0-07:49305] [ 4] /opt/ohpc/pub/compiler/gcc/5.4.0/lib64/libstdc++.so.6(_Znwm+0x2c)[0x7f29a203504c] [zagros-0-07:49305] [ 5] /opt/ohpc/pub/compiler/gcc/5.4.0/lib64/libstdc++.so.6(_Znam+0x9)[0x7f29a20350d9] [zagros-0-07:49305] [ 6] snappyHexMesh(_ZN4Foam4ListIiE7setSizeEi+0x2e)[0x423b4e] [zagros-0-07:49305] [ 7] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam11DynamicListIiLj0ELj2E Lj1EE6appendERKi+0x30)[0x7fb93220b020] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam11DynamicListIiLj0ELj2E Lj1EE6appendERKi+0x30)[0x7f29a62d5020] [zagros-0-07:49305] [ 8] [zagros-0-07:49310] [ 8] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZN4Foam14polyTopoChange7addFace ERKNS_4faceEiiiiibiib+0xbd)[0x7f29a3a7414d] [zagros-0-07:49305] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZN4Foam14polyTopoChange7addFace ERKNS_4faceEiiiiibiib+0x28e)[0x7fb92f9aa31e] [zagros-0-07:49310] [ 9] [ 9] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZN4Foam14polyTopoChange9setActi onERKNS_10topoActionE+0x410)[0x7fb92f9ad6e0] [zagros-0-07:49310] [10] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZNK4Foam7hexRef87addFaceERNS_14 polyTopoChangeEiRKNS_4faceEii+0xd9)[0x7fb92fa18bb9] [zagros-0-07:49310] [11] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZN4Foam7hexRef813setRefinementE RKNS_4ListIiEERNS_14polyTopoChangeE+0x280e)[0x7fb92fa2c38e] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZN4Foam14polyTopoChange9setActi onERKNS_10topoActionE+0x410)[0x7f29a3a776e0] [zagros-0-07:49305] [10] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZNK4Foam7hexRef87addFaceERNS_14 polyTopoChangeEiRKNS_4faceEii+0xd9)[0x7f29a3ae2bb9] [zagros-0-07:49305] [11] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZN4Foam7hexRef813setRefinementE RKNS_4ListIiEERNS_14polyTopoChangeE+0x280e)[0x7f29a3af638e] [zagros-0-07:49305] [12] [zagros-0-07:49310] [12] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam14meshRefinement6refin eERKNS_4ListIiEE+0x54)[0x7f29a31d7284] [zagros-0-07:49305] [13] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam14meshRefinement16refi neAndBalanceERKNS_6stringERNS_19decompositionMetho dERNS_16fvMeshDistributeERKNS_4ListIiEEd+0x46)[0x7f29a31d76c6] [zagros-0-07:49305] [14] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam14meshRefinement6refin eERKNS_4ListIiEE+0x54)[0x7fb92f10d284] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam18snappyRefineDriver11 shellRefineERKNS_20refinementParametersEi+0xcff)[0x7f29a3124e8f] [zagros-0-07:49305] [15] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam18snappyRefineDriver8d oRefineERKNS_10dictionaryERKNS_20refinementParamet ersERKNS_14snapParametersEbbS3_+0x59e)[0x7f29a312729e] [zagros-0-07:49305] [16] snappyHexMesh[0x418cb8] [zagros-0-07:49305] [17] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f29a16efb35] [zagros-0-07:49305] [18] snappyHexMesh[0x41a2d2] [zagros-0-07:49305] *** End of error message *** [zagros-0-07:49310] [13] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam14meshRefinement16refi neAndBalanceERKNS_6stringERNS_19decompositionMetho dERNS_16fvMeshDistributeERKNS_4ListIiEEd+0x46)[0x7fb92f10d6c6] [zagros-0-07:49310] [14] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam18snappyRefineDriver11 shellRefineERKNS_20refinementParametersEi+0xcff)[0x7fb92f05ae8f] [zagros-0-07:49310] [15] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam18snappyRefineDriver8d oRefineERKNS_10dictionaryERKNS_20refinementParamet ersERKNS_14snapParametersEbbS3_+0x59e)[0x7fb92f05d29e] [zagros-0-07:49310] [16] snappyHexMesh[0x418cb8] [zagros-0-07:49310] [17] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7fb92d625b35] [zagros-0-07:49310] [18] snappyHexMesh[0x41a2d2] [zagros-0-07:49310] *** End of error message *** [zagros-0-07:49303] *** Process received signal *** [zagros-0-07:49303] Signal: Aborted (6) [zagros-0-07:49303] Signal code: (-6) [zagros-0-07:49303] [ 0] /lib64/libc.so.6(+0x35250)[0x7f02af181250] [zagros-0-07:49303] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7f02af1811d7] [zagros-0-07:49303] [ 2] /lib64/libc.so.6(abort+0x148)[0x7f02af1828c8] [zagros-0-07:49303] [ 3] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam8newErrorEv+0x54)[0x7f02b0242264] [zagros-0-07:49303] [ 4] /opt/ohpc/pub/compiler/gcc/5.4.0/lib64/libstdc++.so.6(_Znwm+0x2c)[0x7f02afab304c] [zagros-0-07:49303] [ 5] /opt/ohpc/pub/compiler/gcc/5.4.0/lib64/libstdc++.so.6(_Znam+0x9)[0x7f02afab30d9] [zagros-0-07:49303] [ 6] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZN4Foam14polyTopoChange19reorde rCompactFacesEiRKNS_4ListIiEE+0x23e)[0x7f02b14f26ce] [zagros-0-07:49303] [ 7] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZN4Foam14polyTopoChange7compact EbbRiRNS_4ListIiEES4_+0xc1b)[0x7f02b14f89ab] [zagros-0-07:49303] [ 8] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZN4Foam14polyTopoChange17compac tAndReorderERKNS_8polyMeshEbbbRiRNS_5FieldINS_6Vec torIdEEEERNS_4ListIiEESC_RNSA_INS_9objectMapEEESF_ SF_SF_SF_SF_SF_SF_RNSA_INS_3MapIiEEEESC_SC_SJ_+0x1 1b)[0x7f02b14f932b] [zagros-0-07:49303] [ 9] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZN4Foam14polyTopoChange10change MeshERNS_8polyMeshEbbbb+0x28d)[0x7f02b14fba2d] [zagros-0-07:49303] [10] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam14meshRefinement6refin eERKNS_4ListIiEE+0x7b)[0x7f02b0c552ab] [zagros-0-07:49303] [11] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam14meshRefinement16refi neAndBalanceERKNS_6stringERNS_19decompositionMetho dERNS_16fvMeshDistributeERKNS_4ListIiEEd+0x46)[0x7f02b0c556c6] [zagros-0-07:49303] [12] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam18snappyRefineDriver11 shellRefineERKNS_20refinementParametersEi+0xcff)[0x7f02b0ba2e8f] [zagros-0-07:49303] [13] /home/OpenFoam/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libsnappyHexMesh.so(_ZN4Foam18snappyRefineDriver8d oRefineERKNS_10dictionaryERKNS_20refinementParamet ersERKNS_14snapParametersEbbS3_+0x59e)[0x7f02b0ba529e] [zagros-0-07:49303] [14] snappyHexMesh[0x418cb8] [zagros-0-07:49303] [15] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f02af16db35] [zagros-0-07:49303] [16] snappyHexMesh[0x41a2d2] [zagros-0-07:49303] *** End of error message *** Do you have any idea if these errors are related? |
[Technical] About OpenFOAM and concave faces or cells | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 4 | October 13, 2021 06:54 |
[snappyHexMesh] Isn't the "concave cells" really wrong? | KeiJun | OpenFOAM Meshing & Mesh Conversion | 2 | March 3, 2016 03:59 |
[mesh manipulation] Is there a built in way to fix concave cells? | richard_vega | OpenFOAM Meshing & Mesh Conversion | 0 | August 18, 2015 14:12 |
[mesh manipulation] Sharp edge problem on concave patches using polyDualMesh without error | keepfit | OpenFOAM Meshing & Mesh Conversion | 1 | November 25, 2014 14:28 |
Problems on Tetrahedra to Polyhedra using polyDualMesh on concave surface object | chnrdu | OpenFOAM Pre-Processing | 2 | July 18, 2009 12:58 |
