[snappyHexMesh] High quality mesh for wind in complex urban environment |
January 14, 2020, 12:15 |
Mr. Argos
Dear all,
I have been exploring the possibility of using snappyHexMesh to generate high quality mesh for simulating a complex urban environment. I have been reading a lot of the information/tutorials of snappy and have been playing with different parameters in the dict file without any success. I wonder if I can get some suggestions here even if I have to switch to other meshing software. The case I have been exploring is the AIJ benchmark case E. The geometry is available online which is not very clean. Below is my blockMeshDict, snappyMeshDict, checkMesh results and a screenshot of the poor mesh. vertices ( (575.0 500 0.0) (-1025 500 0.0) (575.0 -500 0.0) (-1025 -500 0.0) (575.0 500 400) (-1025 500 400) (575.0 -500 400) (-1025 -500 400) ); edges ( ); blocks ( hex ( 0 1 3 2 4 5 7 6) (80 50 20) simpleGrading (1 1 1) ); boundary ( inlet { type patch; faces ( (0 4 6 2) ); } outlet { type patch; faces ( (1 3 7 5) ); } left_side { type patch; faces ( (0 1 5 4) ); } right_side { type patch; faces ( (2 3 7 6) ); } Bottom { type wall; faces ( (0 1 3 2) ); } Top { type patch; faces ( (4 5 7 6) ); } ); mergePatchPairs ( ); // ************************************* // The sHM dict /*--------------------------------*- C++ -*----------------------------------*\\ | ========== | | | \\\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\\ / O peration | Version: 7.0 | | \\\ / A nd | Web: www.OpenFOAM.org | | \\\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Bioclimatic Comfort Toolkit developed by AKT II Ltd. p.art *\\ | in cooperation with GAS Dynamics Ltd. - copyright 2013 - 2019 | \*---------------------------------------------------------------------------*/ FoamFile { version 7.0; format ascii; class dictionary; location "system"; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers false; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to snap the mesh boundary to the surface geometry { TallBuildings.stl { type triSurfaceMesh; name Tall; } LowBuildings.stl { type triSurfaceMesh; name Low; } Ground.stl { type triSurfaceMesh; name Ground; } refCyl1 { type searchableCylinder; point1 (0 0 0); point2 (0 0 5); radius 210; } refCyl2 { type searchableCylinder; point1 (0 0 5); point2 (0 0 25); radius 210; } refCyl3 { type searchableCylinder; point1 (0 0 0); point2 (0 0 100); radius 240; } box1 { type searchableBox; min (-450 -280 0); max (250 280 150); } box2 { type searchableBox; min (-650 -350 0.0); max (350 350 200); } } // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 5000000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not visible from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 15000000; // The surface refinement loop might spend lots of iterations refining just // a few cells. This setting will cause refinement to stop if <= // minimumRefine are selected for refinement. Note: it will at least do one // iteration (unless the number of cells to refine is 0) minRefinementCells 4; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells // nProcs). 0=balance always. maxLoadUnbalance 0.10; // ====================== // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restrLiction, larger means slower // refinement. nCellsBetweenLevels 5; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "TallBuildings.eMesh"; level 7; } { file "LowBuildings.eMesh"; level 7; } { file "Ground.eMesh"; level 3; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that see multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { Tall { // Surface-wise min and max refinement level level (5 5); } Low { // Surface-wise min and max refinement level level (5 5); } Ground { // Surface-wise min and max refinement level level (3 3); } } // Resolve sharp angles on fridges resolveFeatureAngle 30; //was 60; // was 140; // Region-wise refinement refinementRegions { refCyl1 { mode inside; levels ((6 6)); } refCyl2 { mode inside; levels ((5 5)); } refCyl3 { mode inside; levels ((4 4)); } box1 { mode inside; levels ((2 3)); } box2 { mode inside; levels ((3 4)); } } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (0.5 0.5 399.1); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 4; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 2.0; //- Number of mesh displacement relaxation iterations. nSolveIter 300; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 10; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 10; //- Detect (geometric) features by sampling the surface implicitFeatureSnap false; //- Use castellatedMeshControls::features explicitFeatureSnap true; //- Detect features between multiple surfaces // (only for explicitFeatureSnap, default = false) multiRegionFeatureSnap true; } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes false; // Per final patch (so not geometry!) the layer information layers { Tall { nSurfaceLayers 5; } Low { nSurfaceLayers 5; } Ground { nSurfaceLayers 5; } Bottom { nSurfaceLayers 5; } } // Layer thickness specification. This can be specified in one of four ways // - expansionRatio and finalLayerThickness (cell nearest internal mesh) // - expansionRatio and firstLayerThickness (cell on surface) // - overall thickness and firstLayerThickness // - overall thickness and finalLayerThickness // Expansion factor for layer mesh expansionRatio 1.2; // Wanted thickness of the layer furthest away from the wall. // If relativeSizes this is relative to undistorted size of cell // outside layer. //finalLayerThickness 0.6; // Wanted thickness of the layer next to the wall. // If relativeSizes this is relative to undistorted size of cell // outside layer. // firstLayerThickness 0.15; // Wanted overall thickness of layers. // If relativeSizes this is relative to undistorted size of cell // outside layer. thickness 2.0; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. minThickness 0.1; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didnt do anything in 17x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 60; //was 140; //was 180 // At non-patched sides allow mesh to slip if extrusion direction makes // angle larger than slipFeatureAngle. slipFeatureAngle 30; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 3; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 16x! 90 degrees corresponds to 130 in 16x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 40; //was 20 // Max number of iterations after which relaxed meshQuality controls // get used. Up to nRelaxIter it uses the settings in meshQualityControls, // after nRelaxIter it uses the values in meshQualityControls::relaxed. nRelaxedIter 40; //was 20 // Additional reporting: if there are just a few faces where there // are mesh errors (after adding the layers) print their face centres. // This helps in tracking down problematic mesh areas. //additionalReporting true; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { #include "meshQualityDict" // Advanced //- Number of error distribution iterations nSmoothScale 4; //- Amount to scale back displacement at error points errorReduction 0.75; } // Advanced // Flags for optional output // 0 : only write final meshes // 1 : write intermediate meshes // 2 : write volScalarField with cellLevel for postprocessing // 4 : write current intersections as .obj files debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************** *********************** // The CheckMesh results Time = 0 Mesh stats points: 40250300 faces: 105873698 internal faces: 99156162 cells: 32945732 faces per cell: 6.2232601 boundary patches: 11 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 28978166 prisms: 972472 wedges: 0 pyramids: 0 tet wedges: 15337 tetrahedra: 18 polyhedra: 2979739 Breakdown of polyhedra by number of faces: faces number of cells 4 21696 5 107779 6 836681 7 32782 8 17445 9 1346300 10 1495 11 6703 12 386038 13 167 14 4699 15 202124 16 8 17 313 18 15503 21 6 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. <<Writing 14 cells with two non-boundary faces to set twoInternalFacesCells Number of regions: 1 (OK). Checking basic patch addressing... Patch Faces Points Bounding box inlet 3700 4161 (575 -500 5.3846681e-05) (575 500 400) outlet 3700 4160 (-1025 -500 5.3846681e-05) (-1025 500 400) left_side 5920 7115 (-1025 500 5.3846681e-05) (575 500 400) right_side 5920 7109 (-1025 -500 5.3846681e-05) (575 -500 400) Top 4000 5044 (-1025 -500 400) (575 500 400) Tall 95243 102192 (-81.284027 -18.801546 0) (81.284019 18.801546 60) Low 3978575 4283023 (-203.48402 -201.20525 -0.0042305645) (201.01605 197.10155 30.000572) Ground 1452688 1559339 (-1025 -500 -0.01550289) (575 500 0.31501784) Checking geometry... Overall domain bounding box (-1025 -500 -0.01550289) (575 500 400) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-9.3608341e-17 -1.7540154e-16 -3.3648774e-16) OK. Max cell openness = 4.2592341e-16 OK. Max aspect ratio = 11.530236 OK. Minimum face area = 1.6958678e-05. Maximum face area = 400.88004. Face area magnitudes OK. Min volume = 0.00010824744. Max volume = 8018.2976. Total volume = 6.39643e+08. Cell volumes OK. Mesh non-orthogonality Max: 65.001212 average: 9.0806697 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 7.338727, 31 highly skew faces detected which may impair the quality of the results <<Writing 31 skew faces to set skewFaces Coupled point location match (average 0) OK. ***Error in face tets: 3 faces with low quality or negative volume decomposition tets. <<Writing 3 faces with low quality or negative volume decomposition tets to set lowQualityTetFaces *Edges too small, min/max edge length = 6.5240151e-05 20.040594, number too small: 277 <<Writing 277 points on short edges to set shortEdges *There are 37551 faces with concave angles between consecutive edges. Max concave angle = 79.999548 degrees. <<Writing 37551 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.065226377 average = 0.9997403 *There are 1241 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.065226377 <<Writing 1241 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 0 average: 14.566531 ***Cells with small determinant (< 0.001) found, number of cells: 16 <<Writing 16 under-determined cells to set underdeterminedCells ***Concave cells (using face planes) found, number of cells: 1449413 <<Writing 1449413 concave cells to set concaveCells Face interpolation weight : minimum: 0.024761794 average: 0.47339345 ***Faces with small interpolation weight (< 0.05) found, number of faces: 60 <<Writing 60 faces with low interpolation weights to set lowWeightFaces Face volume ratio : minimum: 0.010017619 average: 0.86376538 Face volume ratio check OK. Failed 5 mesh checks. End Although it failed 5 checks, it shouldn't be that bad. You can see from the screenshot (Mesh_at_glance) that the geometry seems to be captured reasonably well. However, the simulation got exploded using 2nd order schemes (could be the same even for 1st order). I tried to add boundary layers but it just looked terrible so I switched off layer addition and just add more refinement to the ground in the hope that I could get better resolution at the ground level for pedestrian wind assessment. But the screenshot of a slice shows the quality is low and ground level resolution is not enough. I am on the edge of giving up snappyHexMesh. Any suggestions would be highly appreciated! Thanks! Last edited by ziboaa; January 15, 2020 at 06:46. |
January 12, 2021, 15:33 |
Mathias Sønderskov Schaltz
Rep Power: 7 |
I had same experience when i was experimenting with layers in urban comfort.
The layer addition was sprayed all over my context randomly with n,layers = [0..2]. I also had issues with the feature refining, but I'll see if there's anything in your dictionary i can borrow |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
[ANSYS Meshing] High quality unstructured hybrid mesh around ship | flinde | ANSYS Meshing & Geometry | 2 | March 3, 2015 18:04 |
[ICEM] how to generate high quality mesh with this geometry? | llrr | ANSYS Meshing & Geometry | 6 | November 23, 2012 05:40 |
mesh quality and independency..!?? | michelle | CFX | 0 | October 15, 2007 05:50 |
