[foamyMesh] foamyQuadMesh creating cells outside stl shape?
Old   July 18, 2018, 10:43
Default foamyQuadMesh creating cells outside stl shape?
Pal Schmitt
wavemaster is on a distinguished road
Dear All,
I started playing around with foamyQuadMesh and managed to create a good looking mesh. Unfortunately it also creates something outside the original STL shape (which is closed).
Is this a bug or some sort of incompetence on my side?
Any comments are much appreciated, example case is attached.
I'm currently running v1806...
Cheers,
Pal
wavemaster is offline   Reply With Quote
Old   January 19, 2020, 23:50
ChongQing
kila is on a distinguished road
I have the same problem with you. It looks like that foamyQuadMesh failed to calculate bounding box correctly.
kila is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 03:02
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
