Pipes inside tank
1 Attachment(s)
I want to simulate flow inside a tank in OpenFoam. I’ve made a simple test tank with pipes that go through the wall and continues inside the tank. The flow comes in trough one pipe and out the other.
The problem is meshing this in Salome when there are pipes inside the tank. I’ve tried multiple approaches but this is the closest one. See attached study. (The file was to big for the forum, uploaded here https://send.firefox.com/download/90...MbFnuzaL_4ss0A) When I run ideasUnvToFoam Mesh_1.unv I get the following errors: Code:
Of 3340 so-called boundary faces 904 belong to two cells and are therefore internal |
1 Attachment(s)
It looks like the problem is the extra faces that are inside the pipes (marked with red dots). I’ve tried removing these without luck. Does any one know how this can be done in Salome?
2 Attachment(s)
Maybe this is a bit too old, but I had a similar problem and maybe this can help someone.
What I did was basically give a "thickness" to the pipe, the solid cube with a pipe sticking out. Then I just did a cut with a "donut-shape" cylinder. Attached some images to help understand the process. Hope this helps someone. |
