[snappyHexMesh] snappyHexMesh not respecting the STL defined location
Old   February 9, 2020, 03:33
Default snappyHexMesh not respecting the STL defined location
Voulet is on a distinguished road
Hi everybody. I try to study how wind is going inside a building.
I'm trying to mesh a volume containing a building (ensemble.stl) which have open vent (ie the .stl has hole)
Here is my blockMesh for a 100x100x100 cube area (50 cells in each direction for now)
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
vertices
    (0 0 0)         //0
    (0 100 0)       //1
    (100 100 0)     //2
    (100 0 0)       //3
    (0 0 100)         //4
    (0 100 100)       //5
    (100 100 100)     //6
    (100 0 100)       //7
blocks
    hex (0 3 2 1 4 7 6 5)
    (50 50 50)
    simpleGrading
        1                  // x-direction expansion ratio
            (0.5 0.5 1)    // 20% y-dir, 38% cells, expansion = 10
            (0.5 0.5 1)    // 80% y-dir, 61% cells, expansion = 1
        1                  // z-direction expansion ratio
// http://openfoamwiki.net/index.php/Scripts/blockMesh_grading_calculation
edges
boundary
    inlet
        type patch;
        faces
            (0 4 5 1)
    outlet
        type patch;
        faces
            (3 7 6 2)
    sol
        type wall;
        faces
            (0 3 7 4)
    haut
        type outlet;
        faces
            (5 6 2 1)
    frontAndBack
        type outlet;
        faces
            (0 1 2 3)
            (4 7 6 5)
And here is my snappyHexMeshDict:
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object snappyHexMeshDict;
    castellatedMesh true;
    snap false;
    addLayers false;
    geometry
        bat
            type triSurfaceMesh;
            file "ensemble.stl";
            centre (25  25 25);
            convertToMeter 1000;
castellatedMeshControls
        maxLocalCells 100000;
        maxGlobalCells 2000000;
        minRefinementCells 0;
        maxLoadUnbalance 0.10;
        nCellsBetweenLevels 3;
        features
        refinementSurfaces
            bat
                level (2 2);
                patchInfo
                    type wall;
        resolveFeatureAngle 30;
        refinementRegions
        locationInMesh (30 30 30 );
        allowFreeStandingZoneFaces false;
    snapControls
        nSmoothPatch 3;
        tolerance 2.0;
        nSolveIter 30;
        nRelaxIter 5;
        nFeatureSnapIter 10;
        implicitFeatureSnap false;
        explicitFeatureSnap true;
        multiRegionFeatureSnap false;
    addLayersControls
        relativeSizes true;
        layers
            "bat.*"
                nSurfaceLayers 3;
        expansionRatio 1.0;
        finalLayerThickness 0.3;
        minThickness 0.1;
        nGrow 0;
        featureAngle 60;
        slipFeatureAngle 30;
        nRelaxIter 3;
        nSmoothSurfaceNormals 1;
        nSmoothNormals 3;
        nSmoothThickness 10;
        maxFaceThicknessRatio 0.5;
        maxThicknessToMedialRatio 0.3;
        minMedianAxisAngle 90;
        nBufferCellsNoExtrude 0;
        nLayerIter 50;
        writeVTK false;
        noErrors false;
        layerRecovery 1;
        growZoneLayers false;
        projectGrownUp 0.0;
    meshQualityControls
        #include "meshQualityDict"
        relaxed
            maxNonOrtho 75;
        nSmoothScale 4;
        errorReduction 0.75;
    writeFlags ( scalarLevels layerSets layerFields );
    mergeTolerance 1e-6;
For now i'm locating the stl a (25 25 25) flying on the cube with:
geometry
        bat
            centre (25  25 25);
Then, doeing only castellatedMesh, the resulting building is located at (0 0 0) and it doesn't look like to my .stl at all
Here is my STL:
Here is a view of the resulting building:
Here is a view of its location through the outlet of my cube:
Do you have any idea or directions where i can investigate ?
Thanks.
Voulet is online now   Reply With Quote
Old   February 9, 2020, 12:39
HPE
Herpes Free Engineer
HPE is on a distinguished road
I think you forgot to attach the last set of items.
Kind regards,
HPE
The OpenFOAM community is the biggest contributor to OpenFOAM; not person A or B. Let's report bugs or issue feature requests in GitLab-OpenFOAM.
Please `design` your questions well. Such effort always pays off well for inquirers and `helpmate`s:
How to create a Minimal, Reproducible Example,
How to give enough info to get help.
HPE is offline   Reply With Quote
Old   February 10, 2020, 08:01
Default picture stl
Here are some link to the related pictures:
https://framapic.org/9cocT3wYeE2h/fQY30CBLkzXv.png
https://framapic.org/QPAf8ksJSkWS/fRGTy17ye08p.png
https://framapic.org/7fCXTEwUFL7M/g3DmJkEqEemN.png
https://framapic.org/0vJHEhZWhywx/VF2RHqhE5q0m.png
Here is a link for sharing my case (.tar.gz)
https://framadrop.org/r/ANx42G_5E1#P...sqIrGA3HxpM0c=
(I don't kown why but my previous message was erased, can a moderator tell me what happened ? I'm seen as spam ?)
Old   February 10, 2020, 08:13
Yes indeed, could you tell me how to share some links ? Is it allowed on the forum ? When i post links from picture uploading site or file uploading site to share my files, the post is deleted after 3 or 4 minutes. Also when i try to embeded the picutre in my post with the bbcodeform possibilitys, i don't have the right to post the message i've an error message:
Forbidden
You don't have permission to access /Forums/newreply.php on this server.
[snappyHexMesh] snappyHexMesh cannot achieve smooth surface from stl alex::cfd OpenFOAM Meshing & Mesh Conversion 2 October 22, 2018 13:39
[snappyHexMesh] snappyHexMesh: How to add layers to part of an STL? Dreoasteh OpenFOAM Meshing & Mesh Conversion 0 May 14, 2018 11:59
[snappyHexMesh] Why does SnappyHexMesh snap out pieces of my stl file? jordan.tracey OpenFOAM Meshing & Mesh Conversion 1 April 21, 2017 07:06
[snappyHexMesh] snappyHexMesh is not using the stl file a_habib OpenFOAM Meshing & Mesh Conversion 8 December 16, 2014 17:50
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
