[mesh manipulation] FOAM Fatal Error: Trying to add 1th face to a cell with 0 faces. |
February 9, 2020, 09:10 |
I am trying to convert a Fluent mesh of a laminar flow in a straight 3D pipe, with an inlet velocity of 1m/s in the negative Z direction. When using the command "fluentMeshToFoam" my command window looks like this, with the following error;
student@ubuntu:~/foam/student-4.1/run/straightPipe3D$ fluentMeshToFoam straightPipeFluid.cas /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 4.1-93fffffdb745 Exec : fluentMeshToFoam straightPipeFluid.cas Date : Feb 09 2020 Time : 12:55:30 Host : "ubuntu" PID : 4297 CtrlDict : "/home/student/foam/student-4.1/run/straightPipe3D/system/controlDict" Case : /home/student/foam/student-4.1/run/straightPipe3D nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Dimension of grid: 3 ;;,||Number of cells: 6281 number of faces: 28295 Number of points: 17204 Other readCellGroupData: 3 1 1889 1 7 Reading uniform cells Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Reading points Read zone2:3 name:fluid patchTypeID:fluid Reading zone data Read zone2:2 name:interior-solid patchTypeID:interior Reading zone data Read zone2:5 name:inlet patchTypeID:velocity-inlet Reading zone data Read zone2:6 name:wall patchTypeID:wall Reading zone data Read zone2:7 nameutlet patchTypeIDressure-outlet Reading zone data FINISHED LEXING --> FOAM FATAL ERROR: Trying to add 1th face to a cell with 0 faces. Face index: 0 Current faces: 0() From function fluentMeshToFoam in file fluentMeshToFoam.L at line 945. FOAM aborting Aborted (core dumped) I have used the command before for other 3D fluent meshes and have successfully converted them to a Foam mesh so I am unsure what I have done incorrectly this time, any help will be greatly appreciated. Thanks! |
February 9, 2020, 12:55 |
Herpes Free Engineer
Rep Power: 12 |
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 17, 2020, 16:01 |
Thanks for the reply
I think it had something to do with FOAM being unable to convert a Fluent mesh that has been made into a poly mesh. I tried this again but left the Fluent mesh as tetrahedral and this seems to work, so I'm assuming if you want a poly mesh then this has to be done after the Fluent mesh has been converted. Kind regards |
Display Modes | |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 11:58 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
