February 26, 2020, 02:58 |
Body Fitting mesh importing error
saidc
Rep Power: 6 |
Hi, I'm trying to import a "body fitting" mesh with using "ideasUnvToFoam". I have a simple geometry (250k Nodes) like the attachment. When i meshing with "NETGEN-1D-2D-3D" everythings is fine but "body fitting" doesn't working. Why i am getting this error, how can i fix it?
Salome V-8.4.0 OpenFoam-7 ERROR Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-1ff648926f77 Exec : ideasUnvToFoam mesh250k.unv Date : Feb 26 2020 Time : 10:37:22 Host : "said" PID : 6245 I/O : uncollated Case : /home/said/OpenFOAM/openfoam7/tutorials/denemeler/pitzDeneme1 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Processing tag:164 Starting reading units at line 3. l:1 units:" SI: Meter (newton)" unitType:2 Unit factors: Length scale : 1 Force scale : 1 Temperature scale : 1 Temperature offset : 273.15 Processing tag:2420 Skipping tag 2420 on line 9 Skipping section at line 9. Processing tag:2411 Starting reading points at line 20. Read 237034 points. Processing tag:2412 Starting reading cells at line 474091. First occurrence of element type 115 for cell 1 at line 474092 Read 117336 cells and 0 boundary faces. Processing tag:2467 Starting reading patches at line 708766. For group 1 named inlet trying to read 0 patch face indices. --> FOAM Warning : From function void readSets(Foam::IFstream&, Foam::DynamicList<Foam::word>&, Foam::DynamicList<Foam::List<int> >&) in file ideasUnvToFoam.C at line 559 Reading "mesh250k.unv" at line 708768 When reading patches expect entity type code 8 Skipping group code -1 --> FOAM FATAL IO ERROR: Attempt to get back from bad stream file: IStringStream.sourceFile at line 0. From function bool Foam::Istream::getBack(Foam::token&) in file db/IOstreams/IOstreams/Istream.C at line 56. FOAM exiting Last edited by saidc.; February 27, 2020 at 07:14. |
body fitting, mesh, netgen, salome |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
