[snappyHexMesh] Problem triyng to mesh an Ahmed body
Old   March 17, 2020, 05:48
Default Problem triyng to mesh an Ahmed body
GV871 is on a distinguished road
Hello everyone,
I am a new user of OpenFOAM, and I am trying to perform a simulation of an Ahmed body.
I designed the geometry using freeCad and exported the .stl of the body.
At this point I use the same commands of the motorbike tutorial.
The problem arise after the snappyHexMesh procedure.
In fact, I obtain only the background blockmesh without the Ahmed body.
But I do not understand what I do wrong.
This archive (AhmedBodyFOAM.zip) contains the case set up and the script to run the case. (EDIT: Of course when I run the script the snappyHexMesh command is uncommented)
Every suggestion will be appreciated.
Thank you for your time
GV871 is offline   Reply With Quote
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
[snappyHexMesh] SnappyHexMesh Internal Mesh problem tenichols19 OpenFOAM Meshing & Mesh Conversion 2 October 2, 2019 07:39
Ahmed body simulation gives unexpected results in su2 6.0 anas651 SU2 0 March 28, 2018 03:42
sliding mesh problem in CFX Saima CFX 45 September 22, 2015 10:53
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
