[Gmsh] merging surfaces for structural mesh
Old   March 17, 2020, 07:02
Default merging surfaces for structural mesh
Gimlas is on a distinguished road
Dear Users,
I have encountered a very basic problem considering GMSH. I am tryign to learn how to use this softwere however I cannot find solution to my issue. I have a geometry STP file with a complex geometry which I would like to mesh. The geometry is divided in such a way that the structural mesh should be generated.
The problematic part of the body is presented in the figure below. When the geometry is imported into the GMSH an additional line is generated. This line splits the surface into two smaller ones. The problem is I cannot merge the surfaces using boolean options. In the result it is impossible to generate structural mesh on two of the surfaces since there are 5 vertexes instead of 4 (two lying on the bottom and three on the top).
I am aware that this is a very simple case but could you help mi with that?
Best regards
Gimlas is offline   Reply With Quote
[ICEM] Bad Quality Hybrid Mesh External Flow tim13 ANSYS Meshing & Geometry 0 March 8, 2020 02:22
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 1 July 10, 2019 08:56
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
